Stenod Performance is starting another project car...
Old Mar 31, 2005 | 02:28 PM
Stenod's Avatar
LS1TECH Sponsor
Default Stenod Performance is starting another project car...
Seeing that we are starting to do more work now and harlan's and derty's car seem to be under control. We decided to start another project car.
Were Building up Kevin's (1BADWS6) white Formula WS6 this time as sort of our "Shop Car". Nothing crazy about it, but we hope to be able to run this car in the Extreme street class when it's done.
The car will be the following
Moser 9" with 3.90/4.10 gear
28x15x10.5W
Proshifted T-56 to start, changing over to a TH400 when he gets the $$$
Exeddy Twin Disk Clutch
We have decided the powerplant behind this pig is going to be a solid roller 347 inch LS1 with 6.0l truck heads. the orginal plans were to run a dished piston and GRP aluminum Rod in this car, but after extensive talks with the boys at APE (Nick D) and W2W (Kurt and engine building staff), we quickly decided against that! lol! seeing that we want to still drive this car on the street once in a while. Anyways, here's the engine combo we are deciding to run thanks to the guys at W2W and some help from the guys at APE.
LS1 block
Mahle 3.905 custom W2W turbo Pistons
Howards 6.125 4340 rods specd by W2W
W2W custom Ring stack
Stock crankshaft
Seeing that the largest Turbo's we can run in extreme street is either a single 82mm or a pair of twin 60's. We've decided to run the Twin 60-1 turbonetics turbo's. The guys at AGP turbo have been great in helping us out with getting turbo's and getting them to us quickly. We should have turbo's and the wastegates by the end of the week. The turbo's will be mounted high and in front of the engine with the radiator stood straight up and down for more clearance.
You guys can stay up on our project by checking out our website. www.stenodperformance.com in the picture gallery section. We have some five pictures of the project so far, but mainly just of the cage we started bending up that last few nights.
Should be a fun project. We'll keep you guys updated
Stenod
Old Mar 31, 2005 | 02:35 PM
Boostaholic's Avatar
What kind of headers are you going to use on that? Duplicates of harlan's old headers?
Old Mar 31, 2005 | 02:36 PM
sb427f-car's Avatar
SSU'S Vice Mod
What's a "pro shifted" t56?
Old Mar 31, 2005 | 02:37 PM
Ben R's Avatar
Sounds like fun!
Old Mar 31, 2005 | 02:39 PM
gator's 99TA's Avatar
sweet. another group not affraid to push the envelope
Old Mar 31, 2005 | 02:41 PM
Got Me SOM's Avatar
for fun factor i'd keep the proshifted t 56
sb427f-car's Avatar
SSU'S Vice Mod
I wanna see how well that works for yall...As I might change my plans once more
Old Mar 31, 2005 | 02:42 PM
sb427f-car's Avatar
SSU'S Vice Mod
Is that a T56 that's just beefed up that allows you to just keep pulling gears?? No clutching?
Old Mar 31, 2005 | 02:47 PM
sb427f-car's Avatar
SSU'S Vice Mod
It's surpising how much room is in there with all the non-escential "junk" gone. How do yall get around emissions though?
Old Mar 31, 2005 | 02:50 PM
sb427f-car's Avatar
SSU'S Vice Mod
Good lord...those are some tall @$$ vavle covers. What kinda cam specs are we gonna be talking about
Old Mar 31, 2005 | 04:08 PM
Armageddon's Avatar
...with cheese.
im also interested in what a proshifted t56 is? that car looks like its gonna be sweet!
Old Mar 31, 2005 | 04:16 PM
sb427f-car's Avatar
SSU'S Vice Mod
Those valve covers look like they're clearance for BIG LIFT! Gotta love SBs running BB Cams.
Old Mar 31, 2005 | 04:22 PM
FSTR-THANU's Avatar
Outlaw 10.5 Director
Nice Joe! In pic 4 of 5 I can see you put the rear bars directly on the thin sheet metal shelf, did you add some structure over the gas tank on the bottom side of the floor to support them bars?
When are you going to post pictures of Derty's new turbo beast? Or is that car top secret.
Tom
Old Mar 31, 2005 | 04:34 PM
30th TA 0219's Avatar
no fair seeking outside vendor's help! Now you're not the little guys to root for LOL
Sounds awesome, but remember what we expect of you guys...the bar is rather high! You guys are just completely hardco.....oops never mind!
Old Mar 31, 2005 | 04:45 PM
DERTY's Avatar
The Bull
Tom, The rear bars are on plates in the rear, I think the flash on the camera made them look like the sheetmetal.
Beyond that, no pictures or no comments from myself. It will get done when it gets done. Hopefully later this summer I can drive it again.
Old Mar 31, 2005 | 05:05 PM
Stenod's Avatar
LS1TECH Sponsor
Cam is going to be sort of big, not outragous though.
pretty sure the specs are somewhere in the area of high 250's low 260's duration @ .050 680's lift and running on a 115LSA. Just a small turbo cam
Tom- Once we get the rest of the rear bars in, most of the cage structure will be supported off the main hoop and the rear shock tower area. But derty's picture does make it hard to see the 6x6 1/8 plate added to the car back there.
Stenod
Old Mar 31, 2005 | 05:06 PM
2000 Tran Zam's Avatar
double post
Old Mar 31, 2005 | 05:07 PM
Stenod
forgive my ignorance, but how many cubes is a 3.9xxx stroke gonna be? cause thats a huge FI cam isnt it?
edit: i guess its a 347. man, good luck, thats a huge cam!
Old Mar 31, 2005 | 06:37 PM
gnx7's Avatar
A "pro-shifted" T56 has been modified for drag racing and uses straight cut gears (stronger) and will only upshift. You can power shift it with confidence meaning keeping it WOT between shifts and it should be able to take the abuse. It will not downshift with this modification. Many serious drag racers do this wink wink.....
At least that is my understanding.
That sounds like a cool project. Should rip.
-Mark
Old Mar 31, 2005 | 06:52 PM
Murdock's Avatar
Pro shift from Liberty's:
http://www.libertysgears.com/proshift.htm
Read all about it. . . .
