CAS intercooler installers I need Help.
Old Apr 3, 2005 | 08:59 PM
camarogod98's Avatar
Default CAS intercooler installers I need Help.
Im having trouble figuring out how the CAS intercooler goes in. Does the intercooler lay right next to the A/C condensor or does it angle away from it?
Does anybody have a picture of how it goes in? Can somebody take on for me?
I really need your help so i can get my car done and back on the road...spring is here!
Old Apr 4, 2005 | 12:18 PM
chasgiv3's Avatar
Hopefully my setup is similar to yours. Mine was the prototype kit. The pictures below show you where it's mounted and at what angle. If not let me know so I can hopefully give you a hand with understanding its mounting. The IC goes in front of everything. Mines a TA WS6 so I'm not sure if it makes a difference.
Old Apr 4, 2005 | 03:43 PM
Default thanks for the pictures
a picture is worth a 1000 words!
Thats kinda funny that the intercooler hangs down that low....Seams like it would hit stuff.
If i have any more questions i might PM you.
Were they able to tune your car good? Does it run nice and smooth throughout the RPM range?
Old Apr 4, 2005 | 03:58 PM
chasgiv3's Avatar
Tuning isn't an issue.
The intercooler is at the same height of the bottom of the front nose and higher than the oil pan. I've never hit anything with it.
Old Apr 5, 2005 | 05:54 PM
Default more questions
Do you know if i need to notch the radiator support for clearance were the hose runs between the radiator support and the A/C condensor?
Do you have any pictures of where the airfilters go, if not can you take some pictures for me? Have any idea what the K&N part number is or atleast what size filters they are.
Old Apr 6, 2005 | 01:49 PM
chasgiv3's Avatar
No notching necessary
Let me check on the airfilters....I have the part numbers in an email somewhere. Tony D. had sent it to me.
Old Apr 6, 2005 | 01:53 PM
chasgiv3's Avatar
Damn I have no pictures of the air filter setup. There was one on the left and one on the right. Mounted with an aluminum fabricated box that would keep the rain off under the corner of the nose. I can't take any pictures since the twins are sold.
Big single for me now with a Turbo400 tranny w/Transbrake.
Old Apr 6, 2005 | 03:23 PM
Default part numbers
It would be really cool if you could find the part numbers for me. Would really help me out.
thanks,
Jay H
Old Apr 7, 2005 | 07:52 AM
Noyzee's Avatar
8 second mod
the filters are mounted right under the black pieces on each side of the car. they had little brackets, if you find a K+N book, look for a filter about 6" long. it has a 2.5" opening, and a 3" round filter. they are pretty small.
pm jammer, he might have pics from my old setup.
i traded the pieces when i sold my kit.
