Question
Old Apr 13, 2005 | 06:52 PM
  #61
ddnspider's Avatar
now thats the oil actually IN the turbo which is different that a regualr oil change
Old Apr 13, 2005 | 06:57 PM
  #62
HellRaiser's Avatar
The turbo use's the engine oil. Theres a feed from the engine and a drain off the turbo into the oil pan.
Old Apr 13, 2005 | 06:58 PM
  #63
MetallicaMatt's Avatar
so if a tube bender is bad...how do I bend the pipe? heat and force?
So the buget kit is what I'm probably going to get. Does the single turbo kit have any major advantages?
Old Apr 13, 2005 | 07:01 PM
  #64
ddnspider's Avatar
headers that about it cause you can get the turbo with the regualr kit for the budget kit for an extra $220
Old Apr 13, 2005 | 07:02 PM
  #65
ddnspider's Avatar
so theres no separate oil you need to change?basically just change your oil like normal?
Old Apr 13, 2005 | 07:03 PM
  #66
HellRaiser's Avatar
Well a tube bender can be good only if the guy thats useing it nknows how. You can buy mandrel bends and piece them together. Have someone weld them up. http://www.performance-curve.com/ind...S&Category=345 they have good deals.
Old Apr 13, 2005 | 07:04 PM
  #67
HellRaiser's Avatar
you got it.
Old Apr 13, 2005 | 07:06 PM
  #68
ddnspider's Avatar
WTF did i read in a book them..is there separate oil in a ball bearing turbo?
Old Apr 13, 2005 | 07:08 PM
  #69
HellRaiser's Avatar
I think some super chargers are set up like that.
Old Apr 13, 2005 | 07:09 PM
  #70
ddnspider's Avatar
maybe that was it.well that makes my life easier cause that was 1 concern.when is your kit going on?
Old Apr 13, 2005 | 07:26 PM
  #71
Sorry, you confused me with this statement. Could you clear yourself please.
So the pipe that I need to buy is 3", probably SS. I'm assuming the intake to the engine is 3"?
Old Apr 13, 2005 | 07:39 PM
  #72
Questions on the upgrades:
TurboXS RFL BOV- $150 -Why would I consider getting this different blow off valve?
PT70 rated at 820hp- $220 -How much extra HP is this really going to get me?
FMIC (comes with no IC piping)- $150 - I'm getting this
S compressor cover w/ 4" inlet and 2.5" outlet (does not add hp)- $75 - What is this?
Old Apr 13, 2005 | 08:01 PM
  #73
ddnspider's Avatar
that BOV ive heard is awesome and people definitely hear it.
its more about where the turbo will give you peak power.
not worth it,its for looks.
Old Apr 13, 2005 | 08:08 PM
  #74
okay, so the budget turbo vs. the upgraded one, where does the power kick in?
Old Apr 13, 2005 | 08:21 PM
  #75
~RedLineLs1~'s Avatar
You should see full boost around 3000 rpm's. The ls1 gets to 3k pretty damn fast, so the lag wont be bad. Not quite sure on the upgraded kit.
Old Apr 13, 2005 | 08:22 PM
  #76
thats easy enough for me!
budget kit here I come!! Nothing can hold me back now!!!
except for the whole, paying for it thing.....damnit
Old Apr 13, 2005 | 08:25 PM
  #77
haha...I'm in the same boat. But I'm getting there...slowly but surely.
Old Apr 13, 2005 | 08:26 PM
  #78
so i'm looking at 5k, for the kit, fuel injectors/pump, guages, new clutch, dyno tune
Old Apr 13, 2005 | 08:32 PM
  #79
Just be prepared to spend more than you had in mind. When you start putting everything together theres a good chance you will end up buying something else. From what I've been told, its also very addicting.
Old Apr 13, 2005 | 08:33 PM
  #80
so i wonder what i'm looking at
damn, i have a feeling this all wont happen for a few years....unless I decide to sell my camaro
