Vortech vs. Procharger....
The procharge has a self contained oiling system. When the blower exploded, parts of the impeller headed for the intercooler, but none made it to the intake.
The vortech, has, in my opinion several things against it.
1. Oil for the vortech comes from a tapped line in the oil pan. In the above situation, metal parts could have gotten back into the engine.
2. The vortech system (F-Bodies) sits ontop of the motor whereas the Procharger system is on the bottom. Heat rises, and it doesnt matter if you are moving or not. That means that there is going to be more heat soak on the vortech than the procharger which is under the engine.
3. The old conversation about air cooled or water cooled. How cool can antifreeze get moving through the engine.
In the end a blower is a blower is a blower, It is all the other pieces that are part of the system that should be questioned.
Not trying to rain on any vortech blowers, this was just an opinion.
Bryan - good point, the air/water system will heat soak because... engines are hot
. Although I'd like to know what temps the Vortech guys are seeing from their air/water systems. IF you buy an ATI kit you'll have to spend more money to fix the belt slippin issues.
look at time in sig for a bolt on vortech blower car, thru an a4. My kit I got polished so when I pop the hood I get lots of oohs and ahhs. It doesn't look that bad.
Jeff
Jeff
Dont sell it put a T trim
You can perform a small test for verification. Get in your vortech powered car, go down the street say a hard 1st, 2nd, 3rd and 4th gear run. Stop the car and feel the plumbing for the intake and the air to water intercooler.
When I do that even after driving all day in stop and go traffic, hard runs, 130mph runs, when I get out the intercooler is cold to the touch, and the intake plumbing is just shy of luke warm.
Being that we dont have double walled tubing, if the intake tube is warm, I would imagine that the heat in the plumbing is transferring to the intake air.
I am by no means saying that Vortech doesnt make a nice setup. I think it is very attractive, and very powerful and I would be using one if it were the only one on the market. However............
