Methanol Injection Kit for ATI Procharger
Old May 15, 2005 | 07:14 PM
MstgKillr's Avatar
Default Methanol Injection Kit for ATI Procharger
Mods in sig, still running on stock engine. I was thinking of adding a methanol injection kit and not increasing the boost or timing, basicly no retune. Would it be ok to add the methanol to lower my A/F to 11.0. I would throw the car back on a dyno to get a proper A/F. I really don't want to increase power just make my setup a litte more safe. Florida summers can get pretty warm. Would doing the above increase power at all, I think I am already pushing it at 557 rwhp. What would be the best injection kit to purchase. In about 6 months I am going to get a built motor so I definatly want a good kit to max out the D-1SC. Hopefully around 700rwhp.
Old May 15, 2005 | 07:45 PM
KraZy's Avatar
Do you think the Meth will help the stock bottom end live longer?
Old May 15, 2005 | 09:07 PM
MstgKillr's Avatar
I am no expert by any means but if the methanol keeps the engine from denotating then I would guess it would help it live longer. If it also adds 50 hp then I would guess it would shorten the life. I was thinking the methanol would be a little added security for that 95* day or that bad tank of gas.
Old May 15, 2005 | 09:56 PM
MIGHTYMOUSE's Avatar
absolutely. but it will make it so safe that you can up the boost or timing some and still be very safe.
Old May 15, 2005 | 10:36 PM
mdhmi's Avatar
You are in Julios back yard. http://www.alkycontrol.com/
Mark
Old May 16, 2005 | 04:46 AM
MstgKillr's Avatar
MightyMouse
You think I could up the boost or timing on a stock bottom end already pushing over 550 rwhp.
Old May 16, 2005 | 11:08 AM
is that 550 on any race gas at all or all only 93?
you would pick up hp without having to up boost or timing.. but you probably could a little too.
Old May 16, 2005 | 11:11 AM
MstgKillr's Avatar
556 rwhp and 485 rwtq on 93 pump gas.
