Spooling Faster?
Old May 19, 2005 | 03:54 PM
KAOS's Avatar
Default Spooling Faster?
is there any way to make a turbo spool faster. as you all know i have a q.m.p. kit and its at full spool by like 3500 i was just wondering if i could reduce that by a few hundred rpm. its a t74 q trim. i know when my wg's were messed up it would spool like a mother. hit 13psi before i knew it. just curious as to what the experts do. thanks in advance
Old May 19, 2005 | 04:17 PM
hellbents10's Avatar
LS1Tech Sponsor
timing and fuel. fatten it up at the bootom of the curve before it starts to build boost. The higher exhaust gas temps from the rich air fuel mix will help spool the turbo faster. More ignition timing will help too. With the rich mix down low you can bump timing up down there. Get as much as you can down low. Remeber tune it more like a NA vehicle before the boost comes in. I usually start with a 11:1 AFR at WOT just as its ready to start boostin, then when it reaches full boost start to lean it out to the upper RPM's to about 11.5-11.8:1.
Old May 19, 2005 | 04:24 PM
KAOS's Avatar
so tune it to be richer before it starts to boost then lean it out?
Old May 19, 2005 | 04:31 PM
MIGHTYMOUSE's Avatar
sounds like they are opening too soon and bleeding off as it builds.
what controller to you have? my e boost you can change the wg crack psi.
Old May 19, 2005 | 04:34 PM
BoostedWS7's Avatar
correct me if im wrong but, richening the a/f will reduce the exhaust temps...., and a lean mix will raise the temps....
Old May 19, 2005 | 04:36 PM
KAOS's Avatar
im running one of mike browns controllers that he uses. only cost me like 20 bucks. it works though. im going to have to break down and buy an eboost. they sound awesome. anybody wanna donate 5o cents. if everybody does i can get one
Old May 19, 2005 | 05:34 PM
LS1Tech Sponsor
Rich=hot.
Old May 19, 2005 | 05:59 PM
Scalpel's Avatar
Originally Posted by hellbents10
Rich=hot.
No, rich = cool.
Lean = hotter vs a richer A/F. You can actually cool your combustion charge with more fuel. That's why you add MORE fuel to nitrous, to cool the combustion charge to a level where it won't pre-ignite, aka detonate, and/or get so hot it melts vital internal engine components.
Old May 20, 2005 | 05:13 AM
KissMySSo1's Avatar
Technically it will get hotter. If tuned right. The trick is to richen it enough were it still burns while in the exaust. (Basically shooting flames) That is whats going to spool it quicker. It's an old trick. Supposebly it works good. But i havn't done it so i couldn't tell you. I don't see a reason for boost before 4500RPM
Old May 20, 2005 | 07:49 AM
GhostZ's Avatar
Full boost by 3500 is great.....why do you want it faster?
Old May 20, 2005 | 08:49 AM
Brains's Avatar
ZAngel's spools HARD, by ~2500 RPM or so (T76 Q trim ball bearing). I've got her boost controller set to max 10 psi and it nails that immediately if you deck the throttle. Not sure if the difference is in the ball bearing cartridge, or the slightly bigger cubes, but that car spools --NOW-- ..
Old May 20, 2005 | 08:58 AM
Got Me SOM's Avatar
to make a turbo go faster, either switch to a ball bearing turbo, turbos work better with a bigger exhaust/downpipe. Switch to 3" if you haven't done so already
Old May 20, 2005 | 09:16 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
just add a shot of nitrous that will things working quicker. lol
Ricky
Old May 20, 2005 | 04:27 PM
KAOS's Avatar
it is a 3 in downpipe just notched to work with the steering knuckle. i dont really know why i want it spool quicker i just like feeling it right now, no hesitation. i dunno just working on it
Old May 20, 2005 | 04:46 PM
turbocuda's Avatar
To spool quicker put a ball spring pressure relief valve in the source line going to the wastegate. What this will do is to keep any pressure from going to the gate until the valve has reached its cracking pressure. this is adjustable and can be set using a typical air compresor and regulator. Thes can be had from grainger or mcmaster-carr.
Old May 20, 2005 | 09:22 PM
1997 vet's Avatar
What is the A/R size of your exhaust housing? If you are running a 1.3 change it to a .96.
Old May 21, 2005 | 09:30 AM
KAOS's Avatar
.96, least that was what i was told by warbird
Old May 21, 2005 | 11:06 AM
Warbird's Avatar
The turbo is a PTE T74 thrust mount with a .96 AR housing. From everything I know, relocating the wastegate from the end of the manifold would likely be your biggest help. In it's current location it is directly in line with the flow of exhaust gases and in all likelyhooh this causes the spring to open early bleeding off boost. Try a heavier spring or change its location.
Old May 21, 2005 | 11:31 AM
Brains's Avatar
I wonder if wastegate difference is also something to think about? We switched Tiff's kit to use a TiAL WG and BOV. She's running a .4 bar spring in the gate, and an electronic boost controller. The vacuum lines route such that the gate is connected to open air until you get near your set boost pressure, then the boost solenoid begins modulating the time between open air and pressure supply to the gate.
Old May 21, 2005 | 11:41 AM
KAOS's Avatar
i have a wg on the cross over but it bled off too much boost on the dyno and when i unhooked it, i held boost fine. you got me.
