Motor and Turbo Ordered, Woohoo
Old Jun 2, 2005 | 02:39 PM
DAPSUPRSLO's Avatar
Default Motor and Turbo Ordered, Woohoo
HPE 408 with Callies Crank, Eagle H-Beam Rods, Weisco Pistons, Main Studs, etc.
Phamspeed kit with intercooler with PTE 76 GTS. Can you say insta spool and hella torque. May not be as efficient as a smaller motor but alot of fun none the less. It's more of a drag car so I should be able to put down the torque. Still deciding on heads but leaning toward the smaller ET offerings (255 cc head).
Old Jun 2, 2005 | 02:51 PM
FastKat's Avatar
Is that short block assembled? What does somethin like that set you back if you don't mind me asking?
Old Jun 2, 2005 | 03:11 PM
DAPSUPRSLO's Avatar
That's the best part. The shortblock was $4600 plus $250 for shipping. I'm in Maryland in HPE is in Texas. He said the Eagle would be up to the job but I may get greedy in the future.
Old Jun 4, 2005 | 12:27 AM
bboyferal's Avatar
That thing's gonna be a monster!
Old Jun 4, 2005 | 01:10 PM
DAPSUPRSLO's Avatar
I hope so. Getting mixed signals. Some think it would have been better to go with a 370 verses the 408 for efficiency reasons. What are your guys thoughts. I think the 408 will spull this turbo super fast and make it fun to drive on the street. The 76 GTS is capable of 1100hp so I would imagine it flows some serious air. Do you think the exhaust side of this turbo with the stock manifolds will be restrictive? Would it be less restrictive with a 370? Thanks.
Old Jun 5, 2005 | 01:18 PM
FastKat's Avatar
Just curious, what's the bore and stroke on the 408 in inches? How bout the 370?
I am sure your 408 is going to be a monster... it's been said before, there aint no replacement for displacement. You have more potential with more cubes! I would be more concerned about the turbo.... I'd sit down and figure out how many boosted CFM of air you are going to run and check it on the compressor map...
as for the manifolds, I don't know... what's in inside diameter of the primaries and the collector? Generally keeping a sensible size will keep exhaust gas velocity high, which is a good thing.
Old Jun 5, 2005 | 01:56 PM
DAPSUPRSLO's Avatar
408: 4" stroke and 4.030" bore
370: 3.622" stroke and 4.030 bore
I'm starting to lean more toward the pte 88 but I'm not sure the phamspeed kit has that as an option anymore. I know the pte 88 won't spool as quick but who cares when the motor is this big and you have a 3000 or higher stall. We'll see.
Old Jun 5, 2005 | 03:55 PM
FastKat's Avatar
I think you did it right with the 408. You still have a little more bore than stroke (like the original 3.893 x 3.622) so I would not worry about upsetting the originally designed characteristics of the engine.
Did you use anything to pick your turbo? I made a spreadsheet that calculates the CFM of airflow your engine is going to generate with and without boost... it helps you look at compressor maps and decide which turbo is right for you and also has some other cool stuff I didn't design... do you want a copy?
Also, where your turbo starts to boost AND how many CFM of exhaust gas you can push through the turbine (at higher RPM and horsepower) without getting choked up is actually decided by the exducer bore -> that's the inside diameter of the exhaust outlet tube on the turbine that goes into the downpipe. Do you know the exducer bores for the T88 and the GTS76?
I honestly think that 408 cubes is going to make your car plenty fun to drive on the street.... and I'm not so sure if you're going to be totally happy with peak torque (and boost) at 3000rpms. If you're setting this up for the track, wouldnt you want your peak torque somewhere inside your shift points? (I think 4000rpms and 6200rpms with stock gears and an M6) Your 408 cubic inches is going to creat A LOT of CFM of airflow and I am thinking that when you start turning up the boost you're going to start choking the 76GTS.
Old Jun 5, 2005 | 05:57 PM
DAPSUPRSLO's Avatar
Sure, send the spread sheet over. I have taken a look at the compressor maps for the 88 along time ago but I have some questions and concerns. Do you happen to have a compressor map for the 76GTS? If I was to go with a huge set of heads, huge throttle body, and short runner manifold isn't it going to be alot harder for me to see the same psi most people are with smaller heads and a smaller throttle body etc.? Or will the backpressure induced by the exhaust side of the turbo induce more psi. If I will not be seeing the same psi but still flowing the same amount of air as a higher boost setup won't the turbo become more efficient? Lots of questions but I'm all ears to any suggestions.
Old Jun 5, 2005 | 07:37 PM
sb427f-car's Avatar
SSU'S Vice Mod
When you get finished, you better be making a trip up to cecil co and let me know when you do. Sounds awsome though, good luck.
Old Jun 5, 2005 | 08:16 PM
DAPSUPRSLO's Avatar
Definately, or atleast to Delmar. This car will see much track time.
Old Jun 5, 2005 | 09:07 PM
FastKat's Avatar
I got your email address and will send that file out tomorrow since it's on my work computer. You will have to run more CFM of air through your better flowing throttle body, intake manifold and heads to get the same boost as someone with more restrictive components (and a lower volumetric efficiency) however I don't think this will hamper performance. As far as I know, it's all about airflow... think of how they compare your engine to an air pump:the more air it can efficiently pump, the more power you will get. Not sure, I could be wrong on the boost part but I think it's all about airflow.
Old Jun 6, 2005 | 12:27 AM
SStroked 410's Avatar
Sounds like you made the right choice but I would go with a T88. Last time I talk to John he said he could make me a custom kit with a T88 but I would have to bring him the car for the custom 1 5/8" headers, 3" exhaust, 4" downpipe
so you should still be able to get a T88.
I am thinking about the same thing 370 vs 410 plus T88
since I just sold my 410 thats set up for n/a and nitrous
Does anyone know if the 410 would make more peak rwhp then the 370? Been told the 410 would make more peak power and through out the whole power band ....but then some say the 410 will only make more bottom to mid range power and make the same peak? If they make the same peak might as well save the $1,500-2,000 on the 4.000 crank and use that towards the turbo.
Old Jun 6, 2005 | 07:00 AM
DAPSUPRSLO's Avatar
I'm not sure, I replied on your other thread to about being interested in this question.
Old Jun 6, 2005 | 08:20 AM
Got Me SOM's Avatar
If its not too late why not go to a lighter rod? The Eagle's are heavy. Less rotational mass will make her spool and spin even faster.
Old Jun 6, 2005 | 08:22 AM
DAPSUPRSLO's Avatar
I was going to go with the comp star but they are hard to get a hold of I think. I may call and ask for the Howards Billet rods, they are not much more I think.
Old Jun 6, 2005 | 08:49 AM
Got Me SOM's Avatar
I spoke with Kevin at W2W and he highly recommends them.
Old Jun 6, 2005 | 08:55 AM
DAPSUPRSLO's Avatar
Yeah, they probably work better. The only thing is though that Big Rick's car, from HPE, uses Eagle rods and he's gone as fast as 8.00 at 173 or so mph. That tells me that they work. I wander if they don't last or something.
Old Jun 6, 2005 | 09:10 AM
sb427f-car's Avatar
SSU'S Vice Mod
You're spot on with that assumption.
FastKat's Avatar
Default tensile load
Don't forget, the most damaging and dangerous real loads (not offset by compressive loads) that the con rods experience are tensile (pulling) loads... and that's experienced at TDC. This load is all about the weight (mass) of your piston and con rod and engine speed!! Speed kills!!
The loads that are experienced are at BDC of the combustion stroke are compressive (pushing) loads. You can put a heck of a lot more compressive loads on those rods than tensile loads. Anything forged is going to be fine... but getting the weight of the con rod down.... now that's just all around better.
I think it really depends on how fast you want to wind this thing up... basically, what kind of red line are you shooting for?
