found the boost limit on my car tonight
The good news is that that car basically maxxes out at 13psi and won't go higher, therefore making it harder for me to blow it up (i think).
Bad news is it won't go over 13psi (catch 22, huh?) Makes 13 psi around 4k in 4th gear.
Car is pretty much done, i'm quite happy with it. One mod I could do is switch to a small a/r turbine housing to get it to spool quicker, but I think at this point i'm just gonna let it alone since it works quite well. We'll see if the bug gets me or not. Next step is to start collecting some parts for the new motor.
The a/f is 11.3:1 with a max egt of about 1425 in the collector doing a 70-140 mph pull in 3rd and 4th (took 10 seconds according to the log), zero knock. Hopefully i'll be able to see 13 psi in 2-4th tomorrow at the track. Last time it would go to 11, then fall to 9.5-10 psi at the top of each gear.
Hoping for a 125 mph trap (it's vegas, don't say it should be higher)
I think slowhawk is right, that's why Jon and I wanted to go bigger....
EDIT: When I saw your post, I though something bad happen'd.
.does that long hose affect the wastegate any. and how long will you run your stock bottem end I want to see how long it will hold.and good luck with your mph.
