#7 Ringlands bad?
Old Aug 7, 2005 | 11:48 AM
TchargedLS1TA's Avatar
Default #7 Ringlands bad?
I've been out of the LS1 game for a while and now am just getting back in.. I have noticed alot about the #7 piston ringlands going bad on this forum.. Funny thing is, my first TTi kit cracked my #7 ringlands.. Is this a common problem, why only #7?
Old Aug 7, 2005 | 12:17 PM
99SS-T's Avatar
Well it is usually the #7 or #8. The reason is that they are at the back of the stock intake manifold. So basically what happens is ALOT more air is forced into those then say the #1 and #2 ports. So the car may be readin that it has a safe AFR but what is happening is that the rich cylinders, #1 #2, are balancing out the AFFR with the lean cylinders, #7 #8. So ya end up runnin a lean AFR in those 2 and overheating or detonating. GL man.
John
Old Aug 7, 2005 | 10:35 PM
Arkangel77's Avatar
How do you counter this problem?
Old Aug 7, 2005 | 11:06 PM
99SS-T's Avatar
A carb like intake with a elbow will counter this. Not cheap but alot better then runnin lean on a cylinder. Some people change the injector that is there and pout one that is a little bigger. GL
John
Old Aug 8, 2005 | 01:04 AM
Zombie's Avatar
Tune it rich. I run 11.0:1 a/f
Old Aug 8, 2005 | 03:30 AM
Arkangel77's Avatar
I plan to tune it rich so Lets hope that is enoughf to ward this problem off?
Old Aug 8, 2005 | 06:41 AM
EPP's Avatar
EPP
Forged pistons will take care of the problem. We see 500 rwhp on my Mustang Chassis Dyno as the limit to the stock pistons. Bob
Old Aug 8, 2005 | 07:05 AM
Wet 1's Avatar
John
To much air being forced into these two cylinders???????????
Sounds to me like these two cylinders might be getting starved for fuel do to insufficiant fuel supply within the rails... dual fed rails with a good fuel system will go a loooooong way.
BTW, forged pistons don't fix the problem... just mask it.
Old Aug 8, 2005 | 08:27 AM
Reject's Avatar
Exotic, is this true, is what this man is saying true?...IM SO CONFUSED!!
Old Aug 8, 2005 | 09:35 AM
Wet 1's Avatar
Changing the piston material does nothing to change the air and fuel distribution. Forged pistons with certainly be more robust and therefore not break as easy, but the problem is still not addressed w/o any other changes...
IMO the reason # 7 always goes is because it's the last injector on the factory fuel rails to be fed (which are plumbed in series from the factory) so it's the first to starve for fuel which causes that cylinder to go lean. Going to a dual feed rail system and making sure there's plenty of fuel pressure solves the problem IMO. Changing the intake doesn't solve the problem either since this fuel starvation problem still exists.
Old Aug 8, 2005 | 11:13 AM
Reject's Avatar
and what about just richening up the 7 and 8 injectors, will that take care of it or will that mask it too?
Old Aug 8, 2005 | 11:29 AM
Wet 1's Avatar
How are you going to do, and measure, that???
The problem IMO is there's no more fuel at the end of the rail since it flows in series... you can't add any more fuel if there's not any to be added!
Old Aug 8, 2005 | 12:50 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Sorry if this seems ignorant, I'm just a newbie to the whole FI scene, but wouldn't a FMU help out a little by blocking or restricting the return fuel supply therefore letting some fuel stay in the end of the rail to be availabe for the #7 & 8 injectors?
Old Aug 8, 2005 | 12:53 PM
Zombie's Avatar
It might if there was a return line
CHRISPY's Avatar
I feel it is airflow related to the cylinder and not fuel related.
Using a slightly larger injector in those two holes would help. It would be nice to control the pulsewidth for each individual cylinder with LS1 edit/HPtuners but you can't.
Old Aug 8, 2005 | 01:59 PM
Reject's Avatar
OHHHHH so then basically it'd be a better idea just to double up on the fuel rails then, then how come the street procharger kits just sell the kit with....ooh they do sell it with the injectors and a hand held programer dont they?
