T76 rear mounted setup at 14 psi dyno
Here is the excuse list.
little less than 1/2 tank of 91, mixxed in 6 gallons of 100 octane. 60% meth 40% water in the alky kit. Car will not make full boost on the dyno the way it does on the street of course since it's a non load bearing dyno. In fact on the street it will creep to 15 psi vs the 14 psi creep I will see on the dyno. All settings on the boost controller were set 100% so that it was just running to what ever the gate would allow it. My biggest problem was I kept spinning the ET streets on the dyno. I'm going to dyno again in a few weeks with nittos. Chunking ET streets is not cool.
On one decent pull that didn't slip quite as much, the car made it to
625 RWHP
I'm getting the data logs hopefully tomorrow or Thurs, then I will post the graphs. I have a 605 pull with some spin I'll scan in tomorrow and post up.
I'm just amazed at how well this car runs. My guess is that on the street when it hits 15 psi i'm around 650 rwhp. The spring just isn't good or consistant for anything past 11 psi unless it has a lot of load (3rd & 4th gear brake boosting).
For those wondering about spool, it makes 13 psi around 4300 on the street and 15 by 5500 as it slowly creeps. On the dyno it hits 13 psi around 5200.
^a 76 is not too much turbo for a 408 by any means.
Yeah like armagedon said..... yell it might not be big enough..... look at the compressor map and compare it to how much CFM the 408 can flow.....
Awsome numbers...
Kyle
thats why I love that Synergy has the Dynapak.
load bearing and since it bolts the hubs none of this wheel spin, have 12 people sit in the trunk crap
awesome numbers, every time I read your posts it makes me feel that much better about planning to run 10psi thru the stock motor. keep up the good work!
The 76 starts to come alive over 10 psi which is fine for me. A 76 is a little on the smaller side for a 408. I will be upgrading mine to an 80 in the future. ^a 76 is not too much turbo for a 408 by any means.
I can even have passangers in the car at the track on midnight mayhem nights which is pretty cool, but bad for times :p
Greg
My ***** aren't in the passanger seat, but they do migrate towards the back of the seat upon accelleration.
