downfalls to low compression?
-Bryan
My car is somewhere between 8:1 and 8.25:1 and it seems to drive okay. I running a big cam with low compression and cold plugs so I clear it out if I idle for a long time or right after a burnout.
It's a 5.7 liter motor. It's pretty hard to make it a dog down low. I use to drive a 2.2 liter turbo car that had a 7.8:1 compression and even it drove fine.
He didn't believe me till I showed him the spec sheet for when I had the motor built. Trending Topics
He didn't believe me till I showed him the spec sheet for when I had the motor built.The Best V8 Stories One Small Block at Time
I call them the outlaws.
As far as being able to still maintain some good gas mileage (primarily long cruse highway, in the 26~27mpg area with a 6spd and have all the things trimmed out), what's probably the best way to obtain that? 8.5:1, 9:1? Obviously that's on 93 or 93/meth. Also, what about running on ethonal? I know from reading a bit on that subject, you need bigger fuel injectors and pumps, so would it be more bennificial to run high compression ratio too since E85 usually has an octane rating of abour 105~106?
As far as driveability, it will depend more on your tune and your set up than the CR. I am shooting for 8.2:1. The car should be ready very shortly.
If you are in NY, drive over to CT, and I will show you.
With 8:1 they can run more boost; however the turbo spool time especially on 88mm+ sized turbos at the line is way longer. With 9:1 the car when off boost is more responsive (meaning they are giving up 30-50hp from the point in compression) and spools much much faster at the line.
It is true you won't be able to run as much boost on the same octane.... (I've never heard any number associated with it), but if you really want the maximum potential from any turbo setup you need to run leaded race gas 116+ with increased timing. The engine will make plenty of power. I think a good compromise would be 8:5:1.
When a 76mm turbo is rated at 1000hp+ and with 346ci of exhaust flow to spool it... I would imagine the compression won't be a factor; however going to an 88/94/100mm setup you are really going to have to look at all the factors to make it work right.
Compression has nothing to do with how a turbo spools. If you run lower compression you run more timing off boost to make up for it, it's a pretty simple concept.
John
