E85 w/ forced induction?
Old Sep 1, 2005 | 10:22 PM
Boostaholic's Avatar
Default E85 w/ forced induction?
This fuel is rated for 105 octane.
If I had a alchahol tolerant fuel system, how would this compare to normal race fuel?
http://www.e85fuel.com/
Old Sep 2, 2005 | 12:56 PM
2000 Tran Zam's Avatar
ya, i saw a post on ls2.com in regards to some people using that fuel as its much cheaper then reg 87 oct even...
Im curious to know as well if this would be a cheap substitute to race fuel.
Old Sep 2, 2005 | 01:02 PM
y2khawk's Avatar
You will need to update to much larger pump and injectors to supply the fuel needed.
depending on the type of alcohol, stoich AF can be in the 5:1 to 7:1 range and enrichment fuel will be south of 6:1 even with an 85% mix.
It's cheaper alright, but more often than not you need double the volume/mass for the same output. Sure, it's a cooler burning fuel and has a higher knock limit., but you'll go through twice as much.
Old Sep 2, 2005 | 01:09 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Exactly right....better have a killer fuel system...lol
Old Sep 2, 2005 | 01:49 PM
Youve seen pics of my fuel system right? at least if youve been following my threads regarding my turbo setup.
What are your thoughts on it working with my setup?
Old Sep 2, 2005 | 02:44 PM
Devil's Due's Avatar
The IRL is making the switch over the next 2 year from mixed Metanol to Ethanol. by 07 they will be running E100. I'm gonna wait and see how that works and listen to what others have to say before I decide to make the switch or not.
Old Sep 2, 2005 | 03:02 PM
smokinHawk's Avatar
ya it was a good idea till that surfaced.
isnt the stoich of E85 something like 9:1 so youll probably be running it around 6:1 and thats alot of fuel. (edit: ya basically what you said)
better get them 160lbers tuned well
the big boys will probably need Two sets
Old Sep 2, 2005 | 04:28 PM
hangslo's Avatar
methanol, ethanol ... they are both virtually the same ... the only important difference is that if you drink one, it could kill you.
Old Sep 2, 2005 | 04:32 PM
sb427f-car's Avatar
SSU'S Vice Mod
https://ls1tech.com/forums/showthrea...=358361&page=1
Hope that helps.
Old Sep 2, 2005 | 04:34 PM
Reject's Avatar
....did i miss something? but why would you want to drink that?!
Old Sep 2, 2005 | 04:40 PM
Sandmann120's Avatar
Ethanol=Corn Squeezin's, white lightnin', MOON SHINE. Well, kinda anyway.
Methanol=distilled from wood. Don't drink it.
Old Sep 2, 2005 | 04:57 PM
black_z's Avatar
I believe E85 has 35% less energy than gasoline does at any given volume.
Old Sep 3, 2005 | 07:12 PM
METAL MAN's Avatar
100% correct, just open the wallet and feed the man! There's not cheap alternative other than a turbo on a Civic
