C5 C5R 427tt coming along..pics inside
My project is coming along.....here is an update with pics.
1998 covrette
C5R block (pics below)
8.7:1 compression .050 quench
Callies Magnum 4.00 crank
Oliver billet rods
Mahle 37.5 cc reverse turbo pistons.
ECS methanol injection with dual nozzles.
A1 Technology MP35 Head studs (260psi tensile strength) 95ft/lb torque
Cam Motion custom turbo grind 232/236 620 lift intake and exhaust 116 lobe seperation.
Jesel Mohawk Adjustable rockers.
AFR castings CNC'd by ET performance 250cc intake runner. Iconel exahust valves.
FAST intake 90mm
Kinsler fuel rails modified to fit to feed and return lines for PTK kit.
90 mm TB cable conversion (pics below)
Modified MAP hookup
3 bar Map
92 lb Delphi injectors / low impedence
Big Stuff 3 Engine management with trans control.
Evans coolant and water pump
ATI dampner Keyed
Barry Grant King Sumo EFI pump
Aeroquip one way check valve
Magna fuel regulator with 1:1 boost reference
-10 supply line...split to 2 -8 lines
-8 return line
Eboost 2 control mounted in Gauge pod, two solenoids
PTK PE61mm twin turbo with polished housing and powder coated exhaust housing.
X-pipe
B&B tri flow exhaust
Custom built 4L80E transmission(every possible upgrade)...I know it will still blow up at some point.
Yank 3600 converter
3:90 rear DTE built...stage 2
DTE transmission Strut
BeCool radiator
Spal dual 2750 cfm fans
Halltech turbo hood...on its way...needs a little repair....
you may need to cut and paste the links....sorry
http://tinypic.com/demjwm.jpg
http://tinypic.com/demk60.jpg
http://tinypic.com/demnvo.jpg
http://tinypic.com/demiid.jpg
http://tinypic.com/demkqa.jpg
http://tinypic.com/deml9w.jpg
http://tinypic.com/demlgg.jpg
http://tinypic.com/demloh.jpg
http://tinypic.com/demn81.jpg
http://tinypic.com/demnfo.jpg
http://tinypic.com/demnnb.jpg
Tom
1998 covrette
Oliver billet rods
FAST intake 90mm
Modified MAP hookup
3 bar Map
ATI dampner Keyed
-8 return line
X-pipe
Yank 3600 converter
BeCool radiator
Tom
Tom you are out of your mind!!! This is going to be one top nothch setup when you're done, it doesn'tlook like you've skimped anywhere!
A couple of questions for you; have you received the PTK yet? If so, how long did it take them to get it to you? Quality of the kit? Can you please explain your fuel system? It looks like you just drilled two holes in the factory tank and installed bulkhead fittings, is that correct? If so, any leaks or concerns with doing this? What did you do to baffle tank to contail fuel? I assume you're not using the factory pump, correct? Did you have to modify the back of the drivers-side fuel rail for firewall clearance? Sorry about all the questions.
Again, sweet setup Tom!!!
I have not received the kit yet.....any day now.....parts are being coated....taking just over 3 months from time of order.
My fuel system is as you said....bulkheads in the factory tank. I removed the factory pump and tubes..except for the feed from the passenger tank. You can run fuel lines into the rear of the manifold without touching the cowl...but I cut mine to avoid any aggrevation.
At this point I have no baffle in the tank....I will see how things work...habent thought of a good design yet. I am not worried about leaks ....just make sure that there are no high spots on the tank where you the bulkheads go.....I have run the pump/fuel system with 80psi...no leaks....the teflon washers do a great jod at sealing.
I should be finished in the next 1-2 months.
I dont feel 8.8 in low compression. This seems to be right where most recommend I plan to run up to 20 psi.....or more
Tom
Tom
Originally Posted by paspar2
Why are you running such a low compression if you have a meth kit on it?
check the parts for sale section, I think someone had a couple for sale that had died shortly after they where hooked up. My suggestion is to go the the Magnafuel Pro Star EFI 600, it seems to be the choice of most people with big setups. That's what I'm going to use in mine, which is very similer to yours.
1998 covrette
Oliver billet rods
FAST intake 90mm
Modified MAP hookup
3 bar Map
ATI dampner Keyed
-8 return line
X-pipe
Yank 3600 converter
BeCool radiator
Tom
1998 covrette
Oliver billet rods
FAST intake 90mm
Modified MAP hookup
3 bar Map
ATI dampner Keyed
-8 return line
X-pipe
Yank 3600 converter
BeCool radiator
Tom
LS1Tech Co-Founder
Sounds great! I have seen third hand some folks complain about that fuel pump over the last couple of years. I ran a Weldon 2025 but couldn't take the noise. I'm running dual Bosch 420L external pumps now.
That pump on the Ohio boys car made "metal mudd". Lucky they had a filter after the pump.
That Bosch pump that John uses is very nice. We just installed two in-tank for John Cunningham's chevy2 wagon so he could run drag week without the noise of the Weldon. They are pretty quite, and deliver enough for some serious steam.
BTW cool build.
Kurt
BTW cool build.
Kurt
Originally Posted by Bryan Wilkinson
Not bad for beginners. Here's a question. Big Stuff 3, very nice, but how are you controlling the stock gauges, and computer display in the dash. Are you piggy backing the BS3 off the stock computer?
FYI if you havent heard yes you can use all your stock gauges with BS3..... PM Mightey Mouse about it....
Bad *** setup. i also was told to stay away from that fuel pump..... return it to who ever you bought it from......
I like the twin Bosch's also but after some talk with my current builder i wanted to run ONE big pump just incase one decided not to work and i found out to late... ...
Kyle
I am running the stock gauges from the stock PCM. Thanks for the insight on the pump issues. I will be researching for a new pump with the inline configuring....not much room for external fuel pump of that size...
What does BG have to say about all the pump failures. Are these pumps being run dry? are they having other issues that are being looked into?
Tom
Tom
