Bore Vs. Stroke?
Old Sep 16, 2005 | 08:56 PM
allthrotle's Avatar
Default Bore Vs. Stroke?
I am going to be building a FI stroker motor, probally a turbo setup. My friend is telling me that I should build a big bore motor with a small stroke and Im thinking that I want to build a big stoke motor with a big bore. I want this car to still be streetable but, Im still looking for big hp numbers. What do you guys think I should do?
Old Sep 16, 2005 | 09:25 PM
TchargedLS1TA's Avatar
Bigger is better.. Bigger stroke wont rev as high, and bigger bore may have some cooling problems, but as far as those go, hog that bitch out..
Old Sep 16, 2005 | 09:29 PM
allthrotle's Avatar
I do plan on sleeving the block and then boring the cylinders to about 4.125 I am just unsure about how much stroke I should give it.
Old Sep 17, 2005 | 12:10 PM
blackz93's Avatar
You have a Vette? Name sounds familiar.
Seems like I made a little video for a guy at Carolina Dragway with that name?
Old Sep 21, 2005 | 08:23 PM
allthrotle's Avatar
nope I wish, I got a 99 firehawk.
Old Sep 21, 2005 | 08:40 PM
hondakiller's Avatar
id save the stroker money and stick with the stock block and build the internals and spend the money elsewhere on a boosted setup. most of the really fast boost cars are stock or near stock cubes. a stock cube motor properly boosted will make enough power to be stupid on the street. just my .02
Old Sep 21, 2005 | 10:48 PM
FastKat's Avatar
There's a guy that has a 4.1" resleeved aluminum block for sale in the "parts for sale" section. Search for "block" and it will come up. I think the displacement of his setup is 393. It includes forged pistons, forged rods and a forgedt stroker crank.
Old Sep 22, 2005 | 09:21 PM
allthrotle's Avatar
hey thanks for letting me know, Ill check that out.
Old Sep 22, 2005 | 11:05 PM
V8_DSM_V8again's Avatar
At 4.125 keeping a headgasket seal can be a PITA...
Just shoot for a 352 engine.
Also consider a LS2 block w stock bore or a truck block with a mild overbore.....
The first 200+mph Lsx did'nt have a huge bore nor a huge stroke.. While both theories have there backers the limitations of space between bores and piston g forces and speed limit each respecitively.
IMHO build an Iron block up anvil tough then make the power thru boost and good tuning...
