3" down pipe for turbotech
Old Feb 17, 2002 | 09:04 PM
smokinHawk's Avatar
Default 3" down pipe for turbotech
Hey cablebandit;
you said you wanted to convert to a 3" down pipe from the previous 2.5", right.
Did you think that there will be any clearance issue with that or do you think it will be fine?
I was thinking of having my local exhaust shoppe make me a 3incher before i get the kit put on.
It doesnt seem to hard to do. Think thats the way to go?
Any other pipe(s) you would recomend on increasing the diameter to??
Will see how fast we can make it to 500rwhp!
<img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Feb 17, 2002 | 10:03 PM
cablebandit's Avatar
Default Re: 3" down pipe for turbotech
I think clearance is a problem. Rob Raymer has redesigned the manifold to accomodate a bigger downpipe I bet. Wait and see the pictures of his setup and see where we can go. I looked at mine and just dont see the room for a bigger pipe.
Old Feb 20, 2002 | 04:35 PM
Terry Burger's Avatar
A 3" will fit but its a tight fit. Any good muffler shop with mandral bends can make one.
Old Feb 20, 2002 | 05:18 PM
I think it will fit fine in an A4 car but the m6 crossover routing looks to be in the way. I guess I'll see later.
Old Feb 20, 2002 | 07:45 PM
smokinHawk's Avatar
Well the only way to find out is to give it a try.
I'll let you guys now by April. <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Feb 20, 2002 | 09:53 PM
Rob Raymer's Avatar
[quote]Originally posted by Terry Burger:
<strong>A 3" will fit but its a tight fit. Any good muffler shop with mandral bends can make one.</strong><hr></blockquote>
Terry, I wish that was true. It takes a VERY tight radius 3" pipe to clear the steering knuckle. We had to special order them bent to our specs to make it fit. I don't think you could find a muffler shop anywhere that would readily have a pipe like that available. IMHO.
So the short answer is, yes, we will be offering a 3" Downpipe for those who would like to upgrade their Turbo tech Kits.
Hope that helps,
Old Feb 21, 2002 | 06:30 AM
smokinHawk's Avatar
Alright then Rob, how much will the 3 incher go for and when will it be available, before april i hope.
I'll test one for you, I'll even buy it from you this time.
I need i need i need! <img src="gr_eek2.gif" border="0"> <img src="gr_eek2.gif" border="0">
Old Feb 21, 2002 | 05:46 PM
Rob let us know when its available. i understand you are working on your kit and that has highest priority. Hopefully it will help the spool time a tick. I'd love to have the t-76 spooled up by 2800. I'm going to pull my manifold and check it out as well. Also, I think I will pull off the crossover and route a larger one like the a4 uses...I'm not lowering so I've got clearance
Old Feb 21, 2002 | 06:11 PM
[quote]
<hr></blockquote>
I guess I am lucky then. <img src="gr_images/icons/wink.gif" border="0"> Or maybe LT1 cars have more space than the LS1s? It cost me around $150 but they were able to make one for me. It was very close to the steering but cleared with almost no dimpling or contact.
Old Feb 21, 2002 | 07:34 PM
heck the one turbotech supplies hits my steering knuckle
Old Feb 22, 2002 | 09:02 AM
Rob Raymer's Avatar
<strong>
I guess I am lucky then. <img src="gr_images/icons/wink.gif" border="0"> Or maybe LT1 cars have more space than the LS1s? It cost me around $150 but they were able to make one for me. It was very close to the steering but cleared with almost no dimpling or contact.</strong><hr></blockquote>
Yes you are lucky. The LT1 has significantly more space for the DP than the LS1. That's why Turbo Tech's 2 1/2" DP hits the steering knuckle. If they had used a tighter radius elbow, the 2 1/2 pipe would have cleared without a problem.
Smokinhawk, we don't have a price on the individual pieces yet. But I don't think the DP will be too bad.
Hope that helps,
Old Feb 22, 2002 | 11:35 AM
smokinHawk's Avatar
LET US KNOW ASAP.
I'D LIKE TO GET THAT IN BEFORE MY INSTALL IN APRIL IF POSSIBLE <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
