I know this has been discussed a lot but what is the best PCV method?
Hey all i am working out the only detail i never really put any thought into for my twin turbo setup. I have seen soo many posts on how to prevent boost from getting into the crankcase but what is a proven method? I am running an iron block with LS6 valley and stock 99 LS1 valvecovers. It seems the general concensus is to get a breather for the passenger valve cover but what about catch cans? I saw some nice oil/air seperators but i don't know what would be the best in my case. I was interested in the catch can to air inlet for drawing out pressure from the block but there are so many mixed reviews i don't want to try it and possibly ruin some components. Here are some links to what i've read:
https://ls1tech.com/forums/showthrea...ight=catch+can
https://ls1tech.com/forums/forced-induction/194091-what-crankcase-evac-breather-setups-you-running.html
Here are some products i am considering buying:
http://www.spmotorsports.com/ATCmisc...ators_oil.html
http://www.jegs.com/cgi-bin/ncommerc...63&prmenbr=361
Basically i would like some help as what to do with all of the vaccuum connections that i have and how it should be hooked up. Thanks!
Greg
Greg
8 sec potential, 12 sec slip
This is a great question, and a good compilation of threads concerning the PCV system and how to set it up on our FI cars. I am waiting on my 8 rib kit to come here in the mail, but it should be here tomorrow, and I hope to crank it up for the first time this week- reborn blown
The PCV is the only thing I have not addressed yet, but glad I came upon this thread for some input. I only have 1 question tho:
For those of you running dual hoses (1 from each side): On the p/s, which location are you running the line from? The one in the back that attaches to the line going to the d/s? Or the one up front that goes into the throttlebody?
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
I called speed inc this week to order some parts and i asked them what they think. The salesman told me on their cars all they use are breathers on both valve covers and they block off all of the PCV ports. So i bought the Metco breather for the pass. VC and i bought a tiny K+N filter for the driver's side. As a teaser i also bought 2 check valves from mcmaster in case i am not happy with this setup. I guess i will find out if this is going to be or not.
Greg
Greg
I run a metco breather in the pass side oil fill, small K&N clamp on beather on the LH side valve cover. The valve cover and TB fresh air hose is blocked off. Then I have an LS6 valley cover with the stock PCV valve going to an AMW catch can, then to a mcmaster check valve, then into the intake manifold behind the TB.
Works fine for me, the PCV is still there for cruising/idling, the AMW catch can gets 99% of the oil before it can go the intake and at WOT the breathers wotk just fine on a well sealed motor, never had a drop of oil off of them. For a big boost race motor I would have some type of vacuum pump but this works for my setup.
Greg
Greg
Now get the LS6 valley cover and run it to a non breather can with a hose on the other side of the can going to the inlet of your turbo/supercharger for vaccum under boost. Cap off the nipple on the intake. This is a great method, I use it and adopted it from Mighty Mouse. I used to have trouble draing oil back into the block from the turbo and now its fine thats how I know this mod eliminates pressure in the case.
KP, same time post similar method.
LS6 valley cover has a 3/8 tube coming out of the front under the T/B. On a Z06 there is a connector to the intake nipple with a check valve. It is a great place to pull crankcase pressure from. I would not however use the Z06 connector as the check valve will not hold back boost, it just wasnt made for that.
Only Z06 have this valley cover but they are pretty cheap so no biggie.
I already have the LS6 valley cover but the person at Speed Inc said it would not be a good idea to have the breathers and the PCV on at the same time. His reasoning was this: i don't want to have unmetered air being sucked in from the PCV since i have the breathers on. If i need to i will put the PCV back on with the check valves that i ordered.
Greg
Greg
Greg
Greg
Unlike some things there is more then one way to do a working PCV setup. The vent into the turbo inlet works but at idle/cruise you will have some positive crankcase pressure. If the rings are sealed well it really wont be a big deal but if it isnt things will get a little stinky under the hood. OTOH if you are running a filter on the turbo it will get some vacuumbetween the filter and inlet at high boost and thats not a bad thing either.
