What cam for single turbo car?
can anyone tell me the specs of a good cam for my setup and a good place to buy one? i am also planning on upgrading to a LS6 intake while i am doing the cam swap. thanks for any info you can give me.
<img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Hope this helps.
the lobe seperation is 114. i don't know a whole lot about cams, but i have the cam card so let me know if you need more information on it.
i don't have any dyno times but with 9lbs of boost i am only hitting 114mph in the quater. since it is a nitrous cam, the car went 118mph with a 100 shot before the turbo. any help would be greatly appreciated. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
But 114 on 9 psi does seem low. You're running the 60-1, might be time to step up to the t76 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
unless you're going BIG, an inverted pattern probably isn't really needed.
but FWIW, my new cam is 228/224 .563/.553 lsa112
a little tight on the LSA, but inverted pattern <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
we shall see
<small>[ April 12, 2002, 10:05 AM: Message edited by: y2khawk ]</small>
<strong>my current cam specs are: 221/221 @.50 w/ .558lift
i don't have any dyno times but with 9lbs of boost i am only hitting 114mph in the quater. since it is a nitrous cam, the car went 118mph with a 100 shot before the turbo. any help would be greatly appreciated. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto. That cam does not sound that bad for a turbo application. With your mph maybe you need to check things over with your motor and turbo. But again that cam does not sound bad at all. From the numbers you gave it almost looks like some turbo grinds.
i don't know the first thing about tuning this car so i need to take it to someone who does. what about LS1 edit? do i need to take it somewhere who has access to that as well? any help would be greatly appreciated. thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
are your heads ported too?
tuning is off.. dont trust your tuner!
do you have a fuel pressure gauge or egt or air-fuel?
the guy i bought it from did the heads/cam for nitrous and then had a 100 shot on the car...it trapped 118 that way on street tires.
now with the turbo i can't get over 114mph with 9lbs of boost. i usually keep it on 6lbs around town. teh tuning was a "mail order" ed wright that cam with the turbo kit. it was done for the current heads/cam but i guess that all needs to be redone wehn the car is put on a dyno?
just need a reputable place to take it and have it dyno tuned to make the max horsepower with this setup. how much does something like this usually run? thanks again
