A new project
Old Oct 8, 2005 | 10:11 AM
  #41
Reckless's Avatar
Super Moderator
That is some pretty pimp stuff Kurt. I imagine the true intention of staged fueling is for nitrous applications? If not, it would be a good way to use it also.
Old Oct 8, 2005 | 11:24 AM
  #42
427's Avatar
427
The reason it was needed is for high hp engines. The 160#hr injectors can only feed 2000hp on gas or 1000hp on methanol. Running 2 160's at the same time makes for impossible idle/burnout troubles. On our dyno, we ran a BB chevy with 24 160#hr injectors on Methanol. When it was idling the first set was on, then at 700hp the second 16 kicked in to run the powerlevels we needed. This gives more ability as the methanol becomes the choice fuel for fast door cars.
Kurt
Old Oct 9, 2005 | 10:53 AM
  #43
Reckless's Avatar
Super Moderator
So was the BS3 already capable of this, or did Big John just make the necessary alterations and add it to BS3? Pretty good idea. Looking forward to seeing the results. Let me know if you need a driver for the Power Tour
Old Oct 9, 2005 | 11:30 AM
  #44
WILWAXU's Avatar
Sweet car!
No doubt you guys will do it right. Should be a cool Power Tour car!
Old Oct 9, 2005 | 11:37 AM
  #45
turbo'd stang's Avatar
Gotta keep the bench seats in it. Glue a box of Kleenex tissues to the dash. Ultimate sleeper.
Old Oct 9, 2005 | 03:30 PM
  #46
chuntington101's Avatar
be n ice to see he twin rotex blower setup! how much would an alloy version of this motor cost as a creat engine????
thanks Chris
Old Oct 9, 2005 | 10:04 PM
  #47
427's Avatar
427
It is a different part number box to run 16 injectors or more. It has only been out a short time.
I think we have a few volunteers to drive, I will add you to the list.
Kurt
Old Oct 9, 2005 | 11:01 PM
  #48
camcojb's Avatar
Kurt
Add me too!
Jody
Old Oct 10, 2005 | 09:02 AM
  #49
427's Avatar
427
Chris,
It will be in the 10,500. range without a intake manifold. It will include coils to oilpan.
Kurt
thanks Chris
Old Oct 10, 2005 | 09:03 AM
  #50
427's Avatar
427
Done!!
Kurt
Originally Posted by camcojb
Add me too!
Jody
Old Oct 10, 2005 | 11:56 PM
  #51
rons 00z's Avatar
You got it. When it reaches a point we will program (80% duty cycle), The box will re-calculate the pulse width for 84#hr. 84#hr will be 65#hr + 19#hr running at the same time. This will result in 78% of the fuel coming from the 65#hr injector that will be fed by the second gas tank with c-16 fuel. When you back off the throttle below approx 300hp (19#hr) the 65#hr injectors will shut down and the box will change pulsewidth for one 19# injector running on the pump gas tank.
This box is available from BS3 now under the name "Staged injection". It does need two tanks/fuel systems and 16 injectors to work but should be the ultimate street set up. We will drive it on Powertour to test that next year.
Kurt
hell yeah kurt thats exactly how i figured it would work. sounds like a perfect way to run a direct port dry shot as well.
Old Oct 11, 2005 | 06:39 AM
  #52
lilbuddy1587's Avatar
Why not do custom internals on the oringal straight 6 and make some power with a fat turbo??
Old Oct 11, 2005 | 06:43 AM
  #53
Chris,
Kurt
thats a really good price! do you have any more engine specs? and what rotex blowers will you be running?
thanks Chris.
Old Oct 11, 2005 | 09:23 AM
  #54
427's Avatar
427
The blowers will be 38-71's or 38-81's. I have done all my testing with the 38-71 so far, they look good at 955hp to the flywheel. The 38-81 should pic up a little power, we will use these as long as the low speed tq does not suffer.
The engine is a LS2 block, Callies crank/rods, Mahle/W2W boost pistons, Cam Motion/W2W camshaft, GM truck coils, ET ported GM cylinder heads, Smith Brothers pushrods, Morel lifters,ARP main/head studs,Inconel ex valves and GM covers and oilpan.
Kurt
Old Oct 12, 2005 | 07:13 AM
  #55
well i can't wait to see some pics of the setup!
Chris.
Old Oct 12, 2005 | 01:27 PM
  #56
Jason99T/A's Avatar
I can shift faster than you.
That looks like a cool project guys. Good luck with it!
Jason
Old Nov 13, 2005 | 09:40 AM
  #57
Boosted One's Avatar
Kurt, Is she gonna be ready for the power tour in 06? That's an awsome project! But I'm a little partial to Nova's
Frank
Old Nov 13, 2005 | 02:22 PM
  #58
427's Avatar
427
The car should be ready for Power Tour 06. We may run a few other things with it this year if time permits.
Kurt
Frank
Old Nov 13, 2005 | 05:58 PM
  #59
FSTR-THANU's Avatar
Outlaw 10.5 Director
Kurt
Do you have any progress pics? I love
Novas!
Tom
Old Nov 13, 2005 | 09:18 PM
  #60
427's Avatar
427
All we have done so far is take it apart. It is sitting on a surface plate waiting its turn!
Kurt
