harlan
Old Jul 29, 2002 | 04:52 PM
Air21's Avatar
Default harlan
which setup are you running, has anyone tried a single setup on a m6? Hows the twins with the m6?
Old Jul 30, 2002 | 05:43 AM
smokinHawk's Avatar
Default Re: harlan
Cablebandit and myself are some of the few single owners (both of us have M6's)
Cablebandit just finished his forged engine rebuild, i think hes still tweaking though
Harlan and myself are finishing our forged engine rebuilds, though Matt is farther along then me, and better off. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
<small>[ July 30, 2002, 05:44 AM: Message edited by: smokinHawk ]</small>
Old Jul 30, 2002 | 05:24 PM
Air21's Avatar
Default Re: harlan
i'm guessing you and candlebait are using the turbotechnology kit? Have you upgraded any of the peices with custom ones?
Old Jul 30, 2002 | 05:29 PM
Air21's Avatar
Default Re: harlan
doesnt robs kit use a larger intercooler and intake pipes? what other hard parts are different besides the DP?
Old Jul 30, 2002 | 05:33 PM
AlienDroid's Avatar
Default Re: harlan
In two months I'm going single with built engine.
Old Jul 30, 2002 | 11:18 PM
zturbo's Avatar
Default Re: harlan
There is lots of things you can change to make the system better....tt system but not sure what robs kit has diff. I would amagin wastegate for sure as he had that upgrade a while back when he sold the tt systems
You can enlarge the downpipe as stated.
Move the wastegate to a proper location (close to the turbo, i wanted to move mine to the elbow above the turbo when i had the kit but decided to go complete custom)
enlarge the crossover tube
enlarge intercooler piping
bigger intercooler
Get a wastegate that is rated for what you are pushing (deltagate as stated on turbonetics site handles 400 hp) <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jul 31, 2002 | 05:43 AM
smokinHawk's Avatar
Default Re: harlan
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Air21:
<strong>i'm guessing you and candlebait are using the turbotechnology kit? Have you upgraded any of the peices with custom ones?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">were working on it. im tring to upgrade my Xover to 2.5 or bigger right around the tranny (shorter distance). want the 3" DP but might have to wait till some one comes out with one.
Old Jul 31, 2002 | 09:06 AM
cablebandit's Avatar
Default Re: harlan
My wastegate seems to be fine where it is. I THOUGHT i had the "racegate" but the sticker fell off...could swear it is tho. I think the intercooler could remain in the same place but be taller...looks to be room (make it hang farther down). I would LIKE to get a bigger log on the turbo manifold but I'll wait to see if Robs is reasonable. I called Robs place to inquire about possible prices but they wouldnt tell me anything yet till their kit is out. Not sure why tho....they could be selling manifolds..downpipes and crossovers NOW. These are not the parts they are having problems getting. nBesides...i only asked for pricing.....
Old Jul 31, 2002 | 11:53 AM
MIGHTYMOUSE's Avatar
Default Re: harlan
best i can understand, you would have to replace the pass. manifold (with longer 00+ one), the downpipe, crossover, And log all at once, they would not fit the tt system any other way.
i would have expected the turbo log to be at least 3" but he still has his saying its a 2.5" log.
Old Jul 31, 2002 | 04:02 PM
zturbo's Avatar
Default Re: harlan
turbonetics wastegate area
<a href="http://groups.msn.com/Zturbo/otherturbosetups.msnw?action=ShowPhoto&PhotoID=228 " target="_blank">
here is another pic of a racegate.</a>
Look at this the one on the right is the racegate. It has a anodized red ring on the bottom and is quite large.
Turbonetics deltagate/racegate demensions
If you measure yours you can see exactly which it is there is no guessing if it is a racegate as it is bigger.
Hope you have the racegate if you paid for it <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Steven
Old Aug 1, 2002 | 12:04 AM
Default Re: harlan
Just talked to George at TT and he says they are going to try to do a 3" dp and crossover for the m6 this week on a car they have there now. If not, I'm thinking of a different manifold design...it can be done....
Old Aug 2, 2002 | 07:23 AM
y2khawk's Avatar
Default Re: harlan
<strong>which setup are you running</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was running a twin kit, stock long block, modified fuel system and stock 6 speed.
The only thing the same in the new setup is the trans and turbos themselves <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Shortblock: stock crank and block, crower billet 6.125" rods, JE 3.910 forged pistons with inverted dome for 8.7:1 CR, 1/16"-1/16"-3/16" C&A rings, clevite rod bearinds, Fed Mog. main bearings, Katech billet main caps. ARP heads studs. Comp 228/224 .540/.540 112LSA
Heads: ported 6.0L heads, 2.02/1.6 ferrea vlaves. '02 LS6 springs, retainers, keepers, etc.
Intake: home ported Holley w/ shortened runners. Big FMIC, 26x11x4.5 - dual 2 1/2" inlets single 4" outlet
clutch: RAM 402 plate, Mcleod rev-loc disc, Mcleod master cyliner
trans: fresh rebuild on T56 by D&D
Fuel sys: 98 style metal tank with rear/bottom mounted sump dual -8 pickups to -12 pump inlet. Aeromotive Pro-series pump (the silver one), -10 feed and return, Aeromotive 5.0L rails w/ custom brackets for the LS1, Pro-Series regulator, 96# injectors w/ low impeadance driver box.
I think there's some other stuff i forgot, but that'll give you the major stuff <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
