83 lb/hr. Injectors and Driver Box Are In!!!
I wired up the driver box and the injectors and basically made a guess with LS1Edit and....
The car fires up and runs great. I still have some fine tuning to do, but my initial report is that everything is working well.
The driver box install was a bit of a pain because I ran 14 guage wire to all of the injectors...but it was worth it.
Now all I have to do is the rest of the fuel system...lol
Scott
Can you run these injectors on a 4xx rwhp setup, just to make space for lots of room for improvement?
Are you going to do a fuel pump next?
<small>[ September 09, 2002, 06:31 PM: Message edited by: AlienDroid ]</small>
I have a 255 intank and a regulator in the car, but with LS1Edit you CAN tune for them pretty well...my first guess looks like it may be pretty damn close <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Scott
Where did you get yours? How much were they?
You are also going to need an impedance converter box from somewhere to handle the low impedance injectors.
However, I have run into a problem tuning and can't seem to get around it. Whenever you stay in a fuel cell too long it seems that the o2s stop switching and the car stays rich.
I need to consult the LS1Edit gurus.
Scott
<small>[ September 10, 2002, 09:43 AM: Message edited by: mexSSican ]</small>
you're gonna run into that problem
Might want to start considering an open loop program with those squirters.
My 96's are in and running for the last 1k miles.
Problem is, the big injectors require much smaller pulse widths at low engine load than the stockers. Or even the 42's.
I'm betting your a-tap pulsewidths are never dropping below like 1.5 or 1.6 ms, but your trims are ramping way down. Then you get a tip in lean stumble when you change cells. Sound about right??
That is exactly what is happening, the pulse width stays at 1.6...and the car stumbles at tip in. So the problem is that this is the lowest PW that the computer can send?
I am going to get in touch with the people that make LS1Edit and see if they can help.
If not, it looks like I will be going open loop!
Thanks,
Scott
Been tuning the car in open loop mode and it is not too bad! It still runs pretty rich at idle and part throttle, but I am slowly getting it there.
The car seems to have lost the hesitation it had when running in closed loop and all the little tuning is bringing back the power.
A dedicated WB is a blessing for this kind of tuning <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Scott
<strong>The car seems to have lost the hesitation it had when running in closed loop and all the little tuning is bringing back the power.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It was your trims learning the car into a hole. the short pulses get clamped to a much higher than needed value, but the trims ramp way down trying to fix the rich condition. You tip in and the trims need to learn back up from the hole once the commanded pulse width goes above the lower limit.
Interesting quirk, but a decent open loop setup will work wonders. Get it setup, pull the O2's and you car run good gas whenever you want <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
