Finally an easy alternative to get more boost out of your Procharger!
MMS is proud to announce the release of our new Blower crank pulley for the LS1 Fbody Procharger kit.
This will give you a big increase in boost without the worry of belt slippage.
Click the pic for more details
<a href="http://www.mmsracing.com/store.cgi?P=MMS11101" target="_blank">
<img src="http://www.mmsracing.com/images/shops/city/products/MMS11101.jpg" alt=" - " /></a>
Take an add'l 10% off using our MMSLAUNCH promotional code.
Dealer inquiries welcome!
<small>[ November 26, 2002, 06:34 PM: Message edited by: Mike Morgan ]</small>
Re: Finally an easy alternative to get more boost out of your Procharger!
Mike,
Is this a combination crank/blower pulley in one, or is it like the ATI and just fits inside the stock dampner? And how does the promotion deal you mentioned work? i would like to jump on one soon, to check it out and see how it works. If you could e-mail me any other info also, i would be greatly appreciative.
Jason
ZYA_LTR@HOTMAIL.COM
Jason
ZYA_LTR@HOTMAIL.COM
Moderator
I may have to try this when I up my boost from the 4.5 to 5 PSI of the 4.10" pulley. I'm sure if I put the 3.20" pulley back on, I will be slipping like a big-dog. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
To keep the boost up, I have to tighten the belt more than I'm comfortable with.
Two questions:
1. What size belt would come with that 7.875 / 4.10 inch combination?
2. If we got a group purchase up, can that sweeten the deal?
Anyway... that price beats $1500 for a Cog or $500 for an 8-rib. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Two questions:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ZYA_LTR:
<strong>Mike,
Jason
ZYA_LTR@HOTMAIL.COM</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep works just like the stock ATI pulley. We are setting it up on a car right this minute. We have a 3.40" pulley on the blower which only made about 7psi on a 382 motor. Based on my calcs it will be about 18 psi with the new pulley. We'll probably end up with about a 3.85" pulley when it's all done, but we are going to run the car up to about 4000rpm to see how the boost curve looks!!!
When you purchase the pulley online use promo code in the checkout to get the add'l discount. The promo is MMSLAUNCH. It is limited to the first one hundred orders placed since the launch of the new site. It will automatically stop working when we reach that.
<strong>Mike,
Jason
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black LS1 T/A:
<strong>I may have to try this when I up my boost from the 4.5 to 5 PSI of the 4.10" pulley. I'm sure if I put the 3.20" pulley back on, I will be slipping like a big-dog. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Two questions:
Anyway... that price beats $1500 for a Cog or $500 for an 8-rib. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">1. I'll have belt sizes soon. It looks like it will be around a 42" belt. I'll know what a 3.85" pulley uses by Monday.
2. No plans on a GP. The price online is already an introductory price. Plus I am still allowing the online order discount.
Two questions:
Here's an update.
Just tested out a car with just a crank pulley swap.
We picked up 150 RWHP at 4100 rpm from before.
It had a 3.40" blower pulley. Now it hits 10 psi as soon as I floor it. Anyway we have to address the fuel system and get a smaller belt since the tensioner is bottomed out.
We're switching to a 3.85" pulley which should get us our 13-15 psi @ 6500 rpm.
It was nice to see a s/c'd LS1 Fbody make some boost though. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JAS:
<strong>Mike, why didn't you just make an 6-rib or 8-rib 8" crank pulley? If you don't mind me asking, where did you come up with 7.875"?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmm, well I was going to go 7.5" until I did some measurements and checked clearance. At that point I realized I could go bigger. But if I went too big, then I wouldn't be able to fit a blower pulley for low boost settings.
We tested an 8 rib setup on another customers car. We had to shim the blower and it really never fit right. These were made by someone else. It was a 7" pulley. After some calcs I realized that I could have similar surface contact with a 6rib and a bigger diameter.
<strong>Not a surprise that you picked up so much power with your crank pulley.
With the stock crank and 3.4" the blower at 4100rpm was spinning at 29,665rpm.
With you crank and 3.4" the blower at 4100rpm is spinning at 38,935rpm.
Basically with stock crank pully, you wouldn't normally hit 39,000rpm until 5400rpm with a 3.4".
Your 7.875" w/ a 3.4" is equivalent to the stock crank with a 2.59" blower pulley. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Actually, that combo would max out the blower at 6500rpm. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
3.85" sound perfect for your pulley. It would be about 10psi or so at 6000rpm. Hmmm....
Nice work Mike!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually the 3.85" will make more than that. The boost curves aren't blower rpm dependent. We ran a 3.85" on a c5 and was making 10 psi at about 5800 rpm. That was with a 7.5" crank pulley. We are using it on a 385 ci motor so it will drop a bit, but I plan on about 12ish at 6k and probably close to 13-14@6700rpm.
I may have it on the dyno tomorrow.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mike Morgan:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JAS:
I may have it on the dyno tomorrow.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mike what has been done to keep the heads from lifting at those high 13-14 psi numbers? Is it an iron block and what is the compression?
If you remember my engine setup, would I be able to handle 12 psi if I lowered the compression to about 9.2:1? 383 Stroker, your heads&cam.
Thanks
Jay Krites
Thanks
Jay Krites
I will be making some of these also but i can beat there price. LOL I will make any diameter SC pulley you need.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by camarogod98:
<strong>I will be making some of these also but i can beat there price. LOL I will make any diameter SC pulley you need.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good for you <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Adkoonerstrator
JAS - That new pulley setup is just not right for you . <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
John <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Moderator
<strong>I will be making some of these also but i can beat there price. LOL I will make any diameter SC pulley you need.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Didn't you want $500+ for a crank/blower pulley combination? What is your price for a 6-Rib ~7.5" pulley?
Put up or shut up. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
CamaroGod, I'm with Black LS1 T/A on this one, if you can do it, than prove it, i was/am all about buying this setup, i wanted your 8-rib setup, but when you came out with the second price of over 500 bucks, that scared most people away, and so if Mike can provide us with a 6 rib setup, to eliminate shimming the blower, which noone wants to do, and give us more contact to eliminate slippage, then he's got my money, so unless you can produce a 6 rib pulley in thuis dimension soon, Mike will be getting my money here soon, as long as i can get in on the 10% promotion. I tried to email you about the setup, but you still haven't posted prices? when can we expect something? if not everyone will be jumping on the MMS bandwagon.
Jason
Jason
I have a 3.2 inch pulley, but with my motor I want to run 15-16 psi, do you have a crank to go with it and belt to get me that much psi or do I have to by the 3.4 and crank pulley from you. If so what is the cost for the 3.4 procharger pulley/ the size and price of the crank pulley and belt. thanks
check my set up , what boost would you run.
<small>[ November 27, 2002, 05:44 PM: Message edited by: scott ws6 ]</small>
What do you mean with put up or shut up?
Ive decided not to make any 6 rib setups. It was mike morgans idea and im not going to steal it from him.
Even though i could make these in my sleep with one hand tied behind my pack haning from a tree upside down in the dark.LOL
I will just make the 8 rib setups if anybody still wants them and if not I will just move on to the corvette crowd who dosent care what stuff cost. The mazak wont get fired up until the first of January as im going on vacation the whole month of december.
