Going to order D-1SC tomorrow, help with the checklist...
for fuel..
42.5lb injectors, 255inline, 255 intank..
Triple gauge pod, with the addition of a boost gauge...
Can't wait.... <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Good luck, hope you plan on low comp pistons and I would do twin intanks vs the intank and inline.
Justin
The X1 cam will work alright for now...the only problem I think will be the LSA...
I got a loan for the blower...only put down $1300..
But, I will see on the dyno how the fuel situation goes...
And if something occurs with the stock bottom end, which I don't think will happen, I'm only going to run 8lbs of boost, so I don't think it should be problem...
Other than that, I trust that Speed Inc. will do another great install and tune once again..
polished plenum looks great in the car. Tom at Speed Inc. is the way to go. All I did was tell him what I was doing, and what Lingenfelter did. He took care of the rest. Speed Inc. did a great job on the car. As he will do urs. What kinda boost you shooting for? On a 7psi pulley im only getting is 4lbs of boost. I was shooting for 5 1/2lbs- 6lbs of boost. But LPE heads flow so well I was only able to see 4lbs. 510rwhp on 4lbs of boost isnt to bad for now. Good Luck. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<strong> The valve size shouldnt make that big a difference because you are forcing the air, they shouldnt choke it at all. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you can run the same amount of air volume through the motor while making less boost (backpressure & heat) it is possibile to make the same amout of power with less strain on the motor (stock bottom end in this case). This is better achived with a 2.08 valve. 2.055 will work fine, but 2.08 would be preffered for big boost applications.
The X1 cam is a reverse split pattern (230/227 I beleive); not ideal for boost IMO. Everyone has there own ideas on what cam will suit them best though..LOL <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Also, I beleive it's a 112lsa which is also not ideal for holding cylinder pressure...I'd rather use a 114 or 115lsa....
Either way though, you'll have fun with that setup Bos <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The compression is like 10:1-10.3:1...
Still in the safe range I think for running that amount of boost...
LS6's are 10.5:1 compression, and I've seen a few running 12lbs of boost, and a lot on like 7-8lbs holding up fine...
? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I brought up the idea originally to him about having twin inlines...I really don't want to spend the money on twin intanks, and if they go out, its all over...
We were also going to try the 255 inline, and see on the dyno if that would give enough fuel, but I decided to do the intank too, not to risk anything...
I should have enough PSI...
My ATI inline died after several thousand miles of street use so I have experienced this first hand. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The big intank also might help if that ever occured though.
John
Do you still want those 28lb injectors??
Let me know.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Yep, whenever you get those injectors out let me know. Thanks alot.
John
I will get those 28's as soon as they come off the car though...
BigBos-with the Heads and Cam your running,you could get away with 12lbs of boost because the Cam will be bleeding off some of the cylinder pressure <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Also if I do indeed hit 8lbs, how much rwhp do you think I will get?
<strong>
Also if I do indeed hit 8lbs, how much rwhp do you think I will get? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Plus what you have now? Over 500.
