LT1 Procharger 12 rib D1SC/P1SC 7.65 and 3.40 people inside!!!
Originally Posted by wicked_95z
Are those the stock pulley sizes?
Originally Posted by CountryMuzicZ28
I have a 42" belt.. Its soooo tight though.. Like the tensioner is maxed out and you can play guitar notes on the belt..
Went out and dug up the 3.40 pulley and a couple belts. The 43" inch belt should work if it's new, but if it streches much, you will run out of tensioner travel, and the tensioner could end up against the blower pulley. The 42" belt should work fine.
One thing to look out for when using the 42" belt, is make sure the spacer on the back side of the bracket on the 9/16 head bolt (for the tensioner) is not hitting the blower. That's what it sounds like you are experiencing. The tensioner was not maxed out on my setup, like you said yours was.
Originally Posted by Ponyhntr
I just so happen to have an LT1 on a stand in the shop with a ProCharger on it...
Actually my tensioner I have going the other way, towards the crank.. Its not tensioned towards the blower.. I tried doing it towards the blower, doesnt seem like it would have fit at all..
I still have it mocked up in the shop, if I can find my camera, I will send you a pic.
