IAT relocate to EGR location. How?
Old Nov 2, 2005 | 08:43 PM
DanaliHD's Avatar
Default IAT relocate to EGR location. How?
I bought a new IAT sensor and harness. I know which MAF wires to cut and connect to the harness. I want to put the IAT sensor in the spot where my EGR tube is now becaue i'm planning on deleting egr and air anyway. How do I get the sensor to stay in the hole? will it just screw in there? I read something about using a pcv grommet or something?
Old Nov 3, 2005 | 11:54 AM
DanaliHD's Avatar
nobody has done this? maybe the car intake is different that the truck intake?
Old Nov 3, 2005 | 02:15 PM
Blown Ta's Avatar
here's how i was gonna do mine, but i dont know what the truck intake looks like.
get a metal or aluminum egr block off plate,(i've seen them on ebay) drill and tap a 3/8 18 npt on the block off plate,screw it on the intake, then screw on the iat sensor.
it should work for you too.
good luck
Old Nov 3, 2005 | 02:34 PM
DanaliHD's Avatar
now i just need to find a 5/8 npt tap
Old Nov 3, 2005 | 06:45 PM
Blown Ta's Avatar
you need a 3/8 18 npt not 5/8. i got mine from a machine shop. dont forget the drill bit too.
Old Nov 3, 2005 | 07:25 PM
DanaliHD's Avatar
thanks. i went to napa and they ordered the tap and drill bit for me. i'll install it tomorrow night maybe. Thanks for the help guys.
Old Nov 5, 2005 | 08:57 PM
DanaliHD's Avatar
done. the friggin drill bit i bought was for a 1/2 drill, which i don't have. I already had a smaller hole in the whipple elbow, so, i hand drilled the hole bigger. yup, just hooked some vice grips up to the bit and kept turning till it was all the way through. lol. then i tapped the hole and i was done. easy install. I've never tapped a hole before. Let the jokes begin.
Old Nov 6, 2005 | 03:39 PM
Blown Ta's Avatar
glad it worked out for ya.
Old Nov 6, 2005 | 09:11 PM
greentahoe's Avatar
What IAT did you get to plug in? It as a male 3/8 end around the IAT already?
Old Nov 6, 2005 | 09:55 PM
MikeGyver's Avatar
Where are you injecting the methanol at? If you get unevaporated droplets on the IAT sensor, it will give false (colder) readings.
Old Nov 6, 2005 | 10:31 PM
DanaliHD's Avatar
the meth sprays just after the blower, the iat is about 6 inches away on the whipple elbow which is connected the the intake manifold. The other option was to put it where the egr is now, but, i already had a hole in the elbow and haven't removed my egr yet cause i can't figure out how to. I was kinda worried about the meth throwing off the iat, but, leaving it before the blower is just silly. There's only a few inches between the blower oulet and the intake manifold so the options are slim. Other truck guys have done the same setup with good results.
greentahoe, i don't quite understand what you are asking me. I used the same iat sensor as everyone else on performancetrucks. I think it's out of a 96 buick or something like that. It has a 3/8"npt end on it.
