STS oil problem
Old Nov 8, 2005 | 01:28 AM
ozzykicks2002's Avatar
Default STS oil problem
So we have my system all done and we decided to put a new oil pump in it. so we put in the ls6 oil pump. now when I get on it I make crazy oil pressure! like I should be at 40 but it will increase all the way up to 60 70 PSI!!! and when we had her on the dyno the oil reture line started to over flow onto the engine! what do I need to do here?
Old Nov 8, 2005 | 03:42 AM
baldurann's Avatar
It was to my understanding that you should be around 40psi oil pressure at idle?
Old Nov 8, 2005 | 02:10 PM
trtturbo's Avatar
figure out where its coming from; the cap where the hole is or the coupler.
If its the cap where the fitting is screwed in, you may try a little thread tape to seal it better. If its the coupler, you may need another one.
I really wouldnt think the engine oil pump would have anything to do with it. It supplies pressure to the turbo, but your scavenging pump supplies the return pressure.
Old Nov 8, 2005 | 02:40 PM
GR33N GoblinM6's Avatar
my friends car is 40-42 idle.. then when he gets on it, it goes to 60-65.. i was told this was normal do to a turbo..
he also has a 05 WRX STi.. and its at 65psi most of the time.. its a turbo car also
Old Nov 8, 2005 | 03:04 PM
Paul F's Avatar
60-70 is going to be normal at WOT in the higher RPMs. I think your oil leaking problem is totally unrelated to the pressure.
Old Nov 8, 2005 | 03:05 PM
neat's Avatar
60-70 PSi at WOT is normal.
If you're leaking from the return line of the turbo, it has nothing to do with the LS6 oil pump. See where it's leaking from and tighten the fitting, use some teflon tape there, or replace the leaking component.
Old Nov 13, 2005 | 07:04 PM
So is there a way to turn down the STS scavage pump? maybe so it does not pump so much?
Old Nov 13, 2005 | 07:20 PM
Jammer's Avatar
Its a two speed pump, depending how its installed...vacuum referenced...or can be set to run high (or prob low) full time.
Old Nov 13, 2005 | 07:28 PM
EPP's Avatar
EPP
The STS return system into the valve cover is not a very good design, in my opinion. It is way too easy for it to leak oil onto the exhaust. We're having a problem with it, and I have read of others who are also experiencing problems. It is totally unrelated to your engines oil pump, as has already been mentioned. Bob
Old Nov 13, 2005 | 07:37 PM
NicD's Avatar
7 Second Club
Just return it to the oil pan like most other turbo kits and stick a breather on the valve cover in place of the oil filler neck.
Old Dec 12, 2005 | 06:44 PM
that is what we are going to do I think..
Old Dec 16, 2005 | 10:02 AM
so does everyone just think that the oil reture line is bad? or that I need to tap my oil pan? or is there a way to turn the oil savage pump down?
Old Dec 16, 2005 | 03:07 PM
NYSS Guy's Avatar
I am removing the PCV system on mine, and I'm going to use one of the nipples off the valve cover to run my return line (one that is used by the PCV. And then I'll stick a breather on the oil fill hole, as noted above. I don't see any reason why that shouldn't work.
Old Dec 28, 2005 | 08:49 PM
Lrry93's Avatar
Any updates on how this worked?
Old Dec 28, 2005 | 09:32 PM
NYSS Guy's Avatar
check your other thread...the car hasn't been started yet. Although, I'm hoping to finally start the car tomorrow!! I'll let you know if it works out.
