humor me, material questions...
Old Nov 20, 2005 | 08:30 PM
frcefed98's Avatar
Default humor me, material questions...
Say I wanted to make some flanges...header and turbo flanges to start...
what materials would be best...
stainless steel choices..
304L, 321, 347...
Mild steel...
4130 cold rolled or A36 Hot rolled
What thickness would be optimal for sealing for header flanges, as well as turbo flanges...3/8th, or 1/2in
No reason really, I just like knowing stuff like this.
Any and all input appreciated.
J
Old Nov 20, 2005 | 08:49 PM
Tiago's Avatar
you don't want to weld 4130 lol. That **** is very difficult to weld properly, if not done right, the weld will break apart very easily. It requires proper preheat, interpass heat, cool down, and post weld heat treating.
Old Nov 20, 2005 | 08:59 PM
frcefed98's Avatar
EXACTLY the kind of input i'm lookin for, don't know much right now, but i'd like to know more of this stuff.
So whatcha rec Tiago ol buddy?
J
Old Nov 20, 2005 | 09:37 PM
69firebird's Avatar
are you thinking about making yourself a set of headers?
Most headers that are made out of mildsteel just use regular mild tubing that I have seen. My fabricator is using regular mild steel tubing, he got from burns stainless.
and the stainless ones I have seen are either 304 or 321 however the welding is a bit different on that. you ahve to have a full MIG setup and the wire is expensive from what Ive herd
Old Nov 21, 2005 | 07:18 AM
frcefed98's Avatar
Nope just wondering what is used for flanges and stuff. I like knowing this kind of stuff.
J
Tiago's Avatar
A36 should be fine for Flanges
Old Nov 21, 2005 | 10:22 AM
ESR's Avatar
ESR
LS1TECH Sponsor
Default BACK to work Tiago
Get back to work so you can go home and finish your car!!!!!!!!!!!!!!
Old Nov 21, 2005 | 10:23 AM
NA$TY-TA's Avatar
J
LIAR...
PM me buddy.
Old Nov 21, 2005 | 10:39 AM
Tiago's Avatar
LOL Im very close, two oil lines and radiator hoses away
Old Nov 21, 2005 | 10:42 AM
NA$TY-TA's Avatar
yes.... and then u can show everyone else your progress that they havent seen.... but know they want to
Old Nov 21, 2005 | 05:00 PM
nitrorocket's Avatar
304 is all you need.
Old Nov 21, 2005 | 05:35 PM
fash00's Avatar
what about aluminum piping?
Old Nov 22, 2005 | 06:54 AM
JIMMYZZ28's Avatar
316L..................
Old Nov 22, 2005 | 12:17 PM
BubaGumpShrimp's Avatar
Everything you need is at home depot. Go to the plumbing section and you have several choices 1. Cast iron gas pipe. 2.Copper water pipe. 3. Pvc pipe.. I have found that theses dont work too well so i went to the electrical section and nabbed some conduit which works way better then any stainless crap that your looking to use...
For all of you that cant figure this out ITS ALL A JOKE.
