Progress Pictures...
Old Dec 16, 2005 | 02:10 AM
Ryan K's Avatar
Pathological Modifier
Default Progress Pictures...
I pulled the engine out of my Camaro last month due to worn out rings/too much blowby. The new motor is all ready to be dropped into the car.
The last motor made 560 RWHP on 10.5 psi. That was a stock long block, Custom cammed 6.0L. The new engine on the other hand is a 370" Futral Short Block with a set of AFR 225's bolted to it. Same Cam 226 intake/222 exhaust. Compression ratio is right at 8.9-9.0:1.
Also TTi upgraded the log with the new "Mondo Log" as the turbo manifold I had been running was one of the originals from 5 years ago... (Not one single crack BTW).
Also have a new Pro Yank Extreme 3400 going in, replacing the WAY too tight 3000 (2200 actual) I ran this year.
This is going to be FUN!
https://ls1tech.com/forums/attachmen...chmentid=49526
https://ls1tech.com/forums/attachmen...chmentid=49525
https://ls1tech.com/forums/attachmen...chmentid=49529
https://ls1tech.com/forums/attachmen...chmentid=49528
Ryan K.
Old Dec 16, 2005 | 02:46 AM
StoleIt's Avatar
NKAWTG...N
thats some perty coating u got on those!
on a side note: holy crap your down pipe looking nothing like mine!
Old Dec 16, 2005 | 05:56 AM
smokinHawk's Avatar
nice i to like the black coating.
amazing your log hadnt cracked, especially with a 6.0L
how much boost have you been running?
Old Dec 16, 2005 | 06:25 AM
Ryan K's Avatar
I am running about 10-11 psi, I am not running a Boost controller just the wastegate spring.
Ryan
Old Dec 16, 2005 | 07:19 AM
NA$TY-TA's Avatar
Looking good Ryan... when do the tracks open up around there??
Old Dec 16, 2005 | 07:41 AM
Ryan K's Avatar
www.bremertonraceway.com
and
www.pacificraceways.com
They start racing at the END of March....
Ryan
Old Dec 16, 2005 | 08:10 AM
onfire's Avatar
Coal Mining Director
Very nice Ryan!
Old Dec 16, 2005 | 08:29 AM
smokinHawk's Avatar
Ryan
hmm thats about how much boost i was running.
only thing i can think of is you had a safer/better tune compared to those who have had theirs crack.
either that or your intercooler really helped out, how long have you had the orginal tti intercooler near the radiator?
Old Dec 16, 2005 | 09:43 AM
MIGHTYMOUSE's Avatar
cool man
Old Dec 16, 2005 | 10:13 AM
NA$TY-TA's Avatar
and
Ryan
Damn That sucks....... were going to go tomorrow night.... i guess thats another good thing about Texas..
Old Dec 16, 2005 | 11:30 AM
Got Me SOM's Avatar
so does that kit enable you to keep the ac? should make some nice power. any reason why you went with an iron block instead of aluminum such as ls2 402?
Old Dec 16, 2005 | 02:19 PM
Nine Ball's Avatar
LS1Tech Co-Founder
What is the largest size turbo that will fit with that hot side kit?
Old Dec 16, 2005 | 02:20 PM
ddnspider's Avatar
Looks good.Nice coating on the hot parts and i like how the did the wastegate,its not at a 90* angle but less to help get the air out.Why only 10-11 #s on a built motor?
Old Dec 16, 2005 | 05:33 PM
Ryan K's Avatar
Actually the 10-11psi was on the stock motor, This motor is going to see a number a bit north of that...
Ryan
Old Dec 16, 2005 | 05:35 PM
Ryan K's Avatar
The most I have seen was the T-76, the issue is clearence with the "frame rails". The Larger turbos mean you have to notch the frame. In fact the T-76-s that TTi use are a bit of a hybrid, it uses the large wheel in a smaller housing. Making it a little less efficient.
Ryan
Old Dec 16, 2005 | 05:41 PM
Ryan K's Avatar
I just got a bunch more Pictures up, but some are alitle fuzzy, Damn shaky hands!
The Rest are : HERE
And Yes, My Garage is a MESS.
Ryan
Old Dec 16, 2005 | 06:23 PM
KAOS's Avatar
does that drain work good for you. thats the same place i have mine, but never really had a chance to test it out.
Old Dec 16, 2005 | 06:43 PM
Ryan K's Avatar
On the last motor I ran it a differnt way, on My Room-mate's Car, we ran his there, and has no issues with smoking at all.
On the inside of the pan, that fitting is flush with the bottom.
Old Dec 16, 2005 | 07:49 PM
ddnspider's Avatar
Ryan
now thats what i like to hear.from your other post i thought that meant u were just pushing ~10#s.
Old Dec 16, 2005 | 08:47 PM
KAOS's Avatar
how did you manage that did you cut the threads short or what. thats the same fitting i have so we will see. hope i dont have to relocate the drain.
