Final pics
Old Dec 22, 2005 | 12:49 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Final pics
Well,for now.
Car is running and took it for a small drive already.In this nice 35 degree weather it show's 8lbs at 3500rpm or so with the controller all the way down.There is no traction in 3 gears probly due to the cold.Here are some pics
Old Dec 22, 2005 | 12:52 PM
KraZy's Avatar
That is one gorgeous set up! I cant wait for the numbers.
After seeing that nice setup I am going to be embarrased to show mine.....hopefully will be done this weekend.
SINISTER's Avatar
looks awsome\
two questions for my knowledge
what altinator bracket is that i like how it places it nicly out of the way..
and your oil feed line what size line is that and where did you getthe fittings i need to get one made for my new set up
thanks
Old Dec 22, 2005 | 01:08 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by SINISTER
looks awsome\
thanks
1-The altinator bracket is from Phamspeed with alot of customizing to get it sturdy.
2-That is just -4 line.I have a shorter Nitrous feed line to go on it someday.
As for the looks,This is why it took me so long since I did and redid the setup many times. My big things were keeping the stock fans and ground clearance.The next one will be done alot faster now that I have the idea.
The exhaust is awesome.Sounds like a stock car with a Corsa
Old Dec 22, 2005 | 01:09 PM
Wet 1's Avatar
Looks GREAT Don!!!!
BTW, that is one ugly MF looking back at me in that first picture!
J/K
Old Dec 22, 2005 | 01:10 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by Wet 1
Looks GREAT Don!!!!
J/K
Ugly and cold MF
Old Dec 22, 2005 | 01:12 PM
Wet 1's Avatar
Cold? now that it's running you should being doing the finish work down at the shop!
Again, congrats to both of you, it looks really nice!
Old Dec 22, 2005 | 01:16 PM
2002 Trans Am's Avatar
Wow that ground clearance is real impressive
Old Dec 22, 2005 | 01:37 PM
RyanJ's Avatar
SSU Moderator
did you modify the t-stat housing at all?
how big is the DP and how does it route?
is that a T4 pt88?
Old Dec 22, 2005 | 01:40 PM
RealQuick's Avatar
nice work Don. Probable could have cleaned the paint in the engine bay when everything was out though
Old Dec 22, 2005 | 01:42 PM
PurEvl's Avatar
is that a T4 pt88?
yes the tstat has been modified(slowhawk chime in)
dp is 3 1/2
yes its a t4 pt88
Old Dec 22, 2005 | 01:44 PM
Cyborg's Avatar
Old Dec 22, 2005 | 01:49 PM
PurEvl's Avatar
next spring when i put a new 500ci motor in
Old Dec 22, 2005 | 01:59 PM
RealQuick's Avatar
Nice! Just take me for a spin with the curent setup before you change it!!
Old Dec 22, 2005 | 02:19 PM
Slowhawk's Avatar
LS1Tech Sponsor
is that a T4 pt88?
Yes,we spun the T-stat and welded on new tabs.Also the lower radiator hose is stainless steel pipe around the Turbo setup.
Old Dec 22, 2005 | 02:21 PM
Slowhawk's Avatar
LS1Tech Sponsor
Not until your driving your car
Old Dec 22, 2005 | 02:54 PM
RealQuick's Avatar
Thats cold blooded Don You know he'll have that 500ci engine in before my car is done...
Old Dec 22, 2005 | 06:00 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
hey grape smuggler,you still selling those welders,pm me if you want
Old Dec 22, 2005 | 06:57 PM
davered00ss's Avatar
Moderator
I can't wait to see what kind of #'s it puts down.
Old Dec 22, 2005 | 07:03 PM
gnx7's Avatar
Congrats... that looks great.
Awaiting numbers as well.
What heads/cam and fuel management system? Stock PCM?
