994rwhp 863rwtq
Old 12-30-2005, 11:31 AM
qqwqeqwrqwqtq's Avatar
Default 994rwhp 863rwtq
We were playing around with our shop car on the dyno and got some new numbers.
994rwhp 863rwtq through an (unlocked! ) turbo 400 and a full 4 inch exhaust system exiting at the bumper.
This is with a mid frame Innovative 88mm turbo, turbo system built in house.
Sportsman 370ci iron motor.
out of the box AFR 225 heads
LS6 intake, 78mm throttle body
236/242 112lsa cam
22psi boost, 23deg timing, C16 fuel
We are now disassembling the car and building a twin system
Graph -> http://www.ls1speed.com/artwork/turbo/graph2B.jpg
System Pics
Old 12-30-2005, 11:42 AM
gnx7's Avatar
Does that downpipe neck from 5" down to 4"? That is a pretty sweet setup and great numbers.
How much more power would that T-88 put down?
What crankshaft?
What rpm is it making full boost at? and size stall convertor?
Old 12-30-2005, 11:52 AM
NKAWTG...N
StoleIt's Avatar
Is this the first speed setup that hasn't dynoed the same rwhp and rwtq? I call BS!
Looks amazing! And great numbers.
Old 12-30-2005, 11:54 AM
gator's 99TA's Avatar
incredible through a th400! what converter?
Old 12-30-2005, 12:20 PM
paspar2's Avatar
Hypothetical question... What would be the gains if you went to a 40X engine? That's pretty sweet...
Old 12-30-2005, 12:38 PM
gnx7- Yes, downpipe is 5in and necks down to 4in to make it past the engine/k-member. Full boost is around 5200 on the dyno, earlier on the street. Our sportsman 370 uses an iron block, stock crank, eagle rods and diamond pistons. This is as far as we've taken this combination, if I had to guess, I would say it could make about 100 more hp maxed out.
stoleit- Thanks
gator's 99TA- TCT 4000
paspar2- As with most any turbo combination, more displacement will make the same or less peak horsepower, and more low end power and torque at a lower boost level and RPM.
We prefer 350-370ci for a turbo application. Smaller displacement will extend the usable rpm range for a given turbo, and also run the turbo in a more efficient range of the compressor map.
Old 12-30-2005, 12:55 PM
Got Me SOM's Avatar
wow. you should get some vids of that beast on the street playing with people before you take it all apart.
friggin awesome!!
Old 12-30-2005, 12:59 PM
V6 Bird's Avatar
236/242 112lsa cam
System Pics
You selling the 88 now?
Old 12-30-2005, 01:46 PM
Jon @ Speed Inc's Avatar
friggin awesome!!
It's not exactly racing season up here I know your's is just about to start but its still a little cold up here
Old 12-30-2005, 02:07 PM
RealQuick's Avatar
Wow!
Old 12-30-2005, 02:10 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,163 Likes on 756 Posts
Nice numbers, thx for sharing!
How much do you gain with open downpipe you think?
Old 12-30-2005, 03:10 PM
Joel@
Guest
Posts: n/a
Very,very nice...Like the setup. Good and clean.
Old 12-30-2005, 04:04 PM
The Juggernaut's Avatar
I'm gonna come steal that system when the shop is closed.
Old 12-30-2005, 04:19 PM
LS1 SPEED's Avatar
we may allow that....being able to see this in a feather weight car like yours would be worth it
7's
Old 12-30-2005, 04:28 PM
It should be 3000# with the funny car cage, wheelie bars and parachute.
Any reason it can't make 30 PSI and 1300 at the wheels?
Wastegates are just extra weight.
leave the door open tonight.
Old 12-30-2005, 04:37 PM
Big Mike's Avatar
That is fuggin awesome!!!!!!!!!!!!!! That has to be a handful on the street!
Old 12-30-2005, 04:40 PM
Nickn20's Avatar
nice, are you guys still using HPT 3 bar on this car??
Old 12-30-2005, 05:00 PM
This car has never had the HPT 3bar on it - that is our street kit cars you are thinking of. We use BS3 on the shop car with our harness to keep the factory gauges.
Old 12-30-2005, 06:19 PM
LS1Tech Co-Founder
Any idea what rpm you made peak rwhp at?
Old 12-30-2005, 07:02 PM
smokinHawk's Avatar
why why why build a twin, this kit seems to have the go. if your running out of turbo, i think you could squeeze a bigger in there.
nice numbers, to bad you didnt get some track passes on it, id like to see that before the tair down
Quick Reply: 994rwhp 863rwtq
