Heads Lifting and compression
Old Jan 27, 2006 | 04:59 PM
Spenser309's Avatar
Default Heads Lifting and compression
Is head lift directly related to cylinder pressure, or is it linked to something else?
If its cylinder pressure, anyone know about where the different types of head studs give out?
Old Jan 27, 2006 | 05:30 PM
Bens3rdgen's Avatar
I've been told that detonation is the culprit most the time. A mismatched turbo can do it as well. Basically it's the spikes in cylinder pressure you want to avoid. I don't know any of the specs.
Old Jan 27, 2006 | 05:36 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Well today a customer of ours dynoed a 370 LS1 with standard ARP studs and AFR heads. The turbo used is our new S78. At 24-25 psi the coolant was starting to pressurize. Looks like our customer is going to the bigger studs.
Old Jan 28, 2006 | 01:05 AM
Spenser309's Avatar
what kind of compression on the 370? iron block?
Old Jan 28, 2006 | 02:26 AM
SStolen's Avatar
25psi!
Old Jan 28, 2006 | 02:45 AM
mahhddgtp's Avatar
Oh god... I'm totally going to need explaination on all of this because I still don't know everything there is to know when it comes to the little things in the engine.. PM me if needed, but...
How does the coolant start to pressurize and what do the (size of the) studs have to do with it? And how would you avoid the spikes in cylinder pressure? I would think it's pretty hard to avoid if you've got a turbo and there's no true way around it.
I have an idea to the answer on each question of mine, but they're probably not truly correct.
When you upgrade to larger studs, what happens and what else is needed? Also, I don't think I can figure out how detonation would lift a head (even though I know it does). What (mechanically/physically) happens to the head when you run into detonation? I know and understand detonation, but pretty much I only see it damaging pistons and every other part below it.
Sorry for being a such a rookie and thread hijacker, but I never grew up with the car knowledge some people did.. hopefully the answer to my post will further answer the thread starters question
Old Jan 28, 2006 | 05:53 AM
KraZy's Avatar
It was funny that only a few years ago we had people saying the heads would lift off at something like 12psi. Then you havent heard much about it.
Old Jan 28, 2006 | 10:51 AM
y2khawk's Avatar
In theory/practice, you spark a motor for peak cylinder pressure to occur ~10 ATDC for best torque. The amount of spark lead you need to achieve that is a function of charge temp, fuel octane, AF ratio, compression ratio, chamber design, etc etc....
The problem is, if you over spark, have a mixture than burns fast, etc, you increase cylinder pressure to quickly and reach peak pressure early. Now you might get lucky and this happens after TDC, not so bad. Since the piston is already on the way down.
The big problem is if you reach peak while the piston is still moving up. You have the cylinder pressure from combustion fighting the static compression force of the piston itself. As you compress the burning mixture is begins to burn even quicker. You now end up with uncontrolled combustion resulting it huge pressure spikes. This is often the audible sound you hear that we call detonation.
Now this is my crude understanding from hanging around the people that really know what's going on.
simple graph on page 2, reasonable read for those interested
Old Jan 28, 2006 | 01:23 PM
hellbents10's Avatar
LS1Tech Sponsor
If was my understanding that 14atdc was a little better for power production as far as peak cylinder pressure goes.
