The truth - 8.5 psi too much on LS6?
Old Jan 30, 2006 | 01:48 PM
wildwhl's Avatar
Default The truth - 8.5 psi too much on LS6?
Gents -
I've searched some but would prefer some qualified opinions. I have an '04 CTS-V with Mag I/C, stock manifolds and exhaust with bolt on RT hi-flow cats. I tune via EFILive.
I just reinstalled the maggie after having some work done to it at magnuson. I placed a 2.6" pulley on at the same time.
Now I build a solid 6 psi from 1500 RPM - 2000 RPM, growing to 7 psi and peaking at about 8.5 psi somewhere around 5000 RPM to redline. This is a seriously fun car now, and I haven't logged any KR in the cool temps of the last few days (50 degrees).
My serious question is whether this is too much for the stock bottom end?
In otherwords, am I going to blow her up? I'm at 4,500 base altitude and am a little worried about what happens when I drop to sea level.
Sorry for being a wimp.
Wildwhl
Old Jan 30, 2006 | 01:58 PM
ls1charged's Avatar
If memory serves me correctly when you drop altitude your going to lean out....which means u really shouldt drive it until you get a retune at sea level.just my $.02
Old Jan 30, 2006 | 02:03 PM
wildwhl's Avatar
ls1charged -
agreed...so I'll log WB02's again and run fat for safety.
How about the level of boost alone - would you have any concerns?
WW
Old Jan 30, 2006 | 02:07 PM
ls1charged's Avatar
So long as the tune is right(ie A/F ~11:1) you should be fine.i wouldnt worry just make your #1 priority the tune.
longrange4u's Avatar
Tune is all that matters up to 10lbs IMHO.... Good tune your engine survives.... bad tune.. you end up like me!
Old Jan 30, 2006 | 02:31 PM
NA$TY-TA's Avatar
I agree the tune is were its at..... id just watch the boost down at sea level also.... i say 8-9 psi on a stock motor....
Kyle
Old Jan 30, 2006 | 02:58 PM
cputech's Avatar
I run between 8 and 9 psi (stock bottom end)
Old Jan 30, 2006 | 03:05 PM
I agree with Kyle... I have 6.0L heads... gives me a point. 8Lbs is a blast... and real safe with a good tune.
Old Jan 30, 2006 | 03:27 PM
Steel Chicken's Avatar
your not gonna lean out when you drop altitude, unless your running MAFless, thats what the MAF is *for*.
Old Jan 30, 2006 | 04:02 PM
wildwhl's Avatar
Still holding off on going to 2bar SD tune...just for that reason
Old Jan 30, 2006 | 06:51 PM
VortechC5's Avatar
The thing to keep in mind is if you are making 8.5 psi at 4500 feet you will have more boost at a lower altitude. With my original SC my car made 8.5 psi in Tempe (~800 feet) where it was tuned. At home at 7000 feet it made 6.5 psi. The difference between the 7000 feet at home and the drag strip at 4900 feet is .5 psi.
Assuming that the maggie has the headroom I would guess that you would see +1.5 psi between your altitude and sea level.
Old Jan 30, 2006 | 07:01 PM
Got Me SOM's Avatar
drop your timing if you want to play it a little more safe.
Old Jan 30, 2006 | 10:41 PM
wildwhl's Avatar
Thanks for all the input LSxians.
I'm going to pull a little timing for now, fatten her up a bit, and spend plenty of time logging/tuning to get it all sorted out. If there were a local dyno tuner it could be a lot simpler, but what FUN would that be
I have to admit - the difference between the boost with the 2.8" and 2.6" pulley from SOTP is amazing. Traction control kicking in at the top of 3rd at 9/10's throttle (wet roads today) is pretty darn
Old Jan 31, 2006 | 05:35 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...Car.php?car=33
You could install a wide band air/fuel gauge in the ash tray where we installed a gauge in the V above. It might make it easier to keep an eye on things. Bob
