sts cough need help!
coughin is the best way I can explain it.
it wasnt everyday but ounce in a while it would start to hesitate
and pop a little. while at idle or under boost but not mid throttle.
but now its constant.
I thought it was a bad tank of gas when it happened last month.
so switched gas stations and had no problems for a bit and now
its doing it again. i just filled up too....
its also pulls timing like crazy. normally im at 16- 15 deg when under full
boost and when this happens it drops down to 7 or 6 deg on my scan
guage should i start with a fuel filter? or try and put a fuel guage onit
and tape it to the windsheild and see if im losing pressure at boost
maybe this gas station has bad gas too now.....
where would you guys start??
if i half throttle it my car runs as smooth as glass but when i nail it ...it
coughs almost like a misfire but its not backfiring at all just little pops in
succession like its coughin...
my car was tuned on 91 octane . and thats what i have been running
any help would be appreciated..
my mods are listed below 42lb injectors walbro pump...
thanks
matt
everything is about 4 months old now.
any one brand to stay away from?
i think im gonna try that and see what happens..
any more suggestions? my fuel filter is about 5 month old too..
but maybe they might have another solution.... Trending Topics
i guess ill start with a fuel filter and go from there
according to my scan guage my map sensor is definatley reading
but i guess it could be my mas airflow sensor on its way out
or just crappy gas again... we'll see
this is driving me crazy
i went out at lunch and its fines now drove it for 20 minutes
not a pop out of it..its like 30 degress warmer now though......
i dont remember what i gapped my plugs at but i did use ngk tr6's
i do have a little pop at idle ... cracked spark plug could be the
culprit i had a hell of time trying to get the plugs in with my big
hands in the way and i may have knocked one and put a harline
crack init. well so far this weekend im doing plugs and the fuel filter.
I dont have a data logging scanner /program and it looks like it
would be beneficial to own that.
im using taylor thundervolt wires.
they are really thick wires almost redicoulous lookin.
I allways used taylor wires on my muscle cars I have owned over
the years so thats why I went with those . i hope they arent the
culprit
but maybe they might have another solution....were backing themselves off even though i tightened them!
i guess i should of cranked on them harder
now its all back to normal. Thanks zombie for the gap sizing
info.. my car is runing better with the .028 gap setting!!!
i have zero hestitation under boost now!
Usually it's something simple.
