Wrapped or coated???
Old Feb 6, 2006 | 11:16 PM
fastlt1's Avatar
Default Wrapped or coated???
The hot side of the turbo kit, which works better header wrap or cermanic coating?
Old Feb 7, 2006 | 08:48 AM
white2001s10's Avatar
IMO coat the inside and wrap the outside, but only if it's stainless.
Old Feb 7, 2006 | 03:07 PM
fastlt1's Avatar
Why if it is stainless?
Old Feb 7, 2006 | 03:22 PM
smokinHawk's Avatar
if you arnt planning on welding on it again, have it coated. then if you want it wrapped later do that too.
Old Feb 7, 2006 | 03:34 PM
fastlt1's Avatar
Which keeps the heat in better?
Old Feb 7, 2006 | 03:55 PM
RyanJ's Avatar
SSU Moderator
Wrap will keep moisture in as well, so be aware of your materials and what not.
Old Feb 8, 2006 | 10:50 AM
Wrap keeps heat in,
coating keeps heat out,
hence my answer.
Anything but stainless will rot away quickly with wrap.
Old Feb 8, 2006 | 11:52 AM
jyeager's Avatar
So if you coated the inside, but on the outside had to choose between coating and wrapping (and assuming it was stainless so it wouldn't rust out) then which one on the outside makes for a better thermal barrier?
Old Feb 8, 2006 | 12:28 PM
My money is on the wrap by far for the outside.
Old Feb 8, 2006 | 12:57 PM
jyeager's Avatar
I'd guess the same when talking about Jet-Hot type coating. But there are TRUE ceramic coatings out there. Those might work better. And look tons better. Oh, and cost tons more.
