Ideas on next round of mods. What you think?
My questions are:Is my current turbo sufficent? Should I go BS3?? Which turbo cam would work best for my goals while being street drivable, which verter, should i upgrade to the new ET Performance heads(which seem badass) over my TEA 2s and if so which ones--The ET 225cc, 245cc, 255cc etc etc??? Also, would the 90/90 setup be worth it over my current LSX78/75mm MTI tb on a stock cube motor?( i figure yes with that much air going through but i dunno for sure)
Im not gonna worry bout rwhp/rwtq numbers so much as i just want low-mid
9s@150mph or better consistantly w/ decent street manners
Any opinions or suggestions would be most appreciated!!!
thanks Guys/Gals
Im just wanting as much input from all the experts/enthusists on here as i can get as well as think everything out throughly before making my final decision & getting the ball rolling on this project in the Fall hopefully
a 4l80e will be heavier but you'll have overdrive. you probably only need a 3500 or so stall.
If you make changes, I'd do the T400 and a good converter and go from there. That cam is good enough for now.
BTW, i thought i would need a lil bigger turbo cam w/ the auto to build boost faster or that not true??
....... Oh yeah and get back to work beotch.
