At what point do you need an LS6 PCV system?
Now that my motor is all apart, I am wondering if I should pick up an LS6 valley cover and convert my existing system to the LS6 PCV system... however I really don't want to do it unless I will need it. Is the LS6 system that much better than the LS1 system?
-Dave
-Dave
I just got lucky and with my new block I ordered it was a LS6. Then I pulled a engine from a Z06 and replaced it with a TSP LS2 402 so I kept the LS6 valley and just put a catch can on it with a check valve back to the intake and a breather on the valve cover. If this doesnt work I will just modify my stock valve covers and do what Kyle did.
Originally Posted by Richiec77
Hey Kyle. What did that run you? Me Likey.
What one??
oh ok ill explain....
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I WAS going to go with a Moroso catchcan/breather but i would need to weld on two -10 an fittings.... so the price for it went thru the roof....
That catch can is on the people's site....... alot of people on TurboMustangs are using it.....
it has two 3/8npt fittings already.....
so im using 3/8npt to -10an fittings.....
then -10an 90's with braided line.
The Valve covers are from Nasty Performance.... give Nate a call..... i added the -10an fittings on them.
If ya want the $$ then PM because the catch-can is not a sponsor.
Kyle
Originally Posted by smokinHawk
sweetness.
at any boost level the ls6 valley cover will help, i need not to be lazy and put mine it.
agg, take the intake off, cover, grind block and reinstall, no wonder ive been putting it off.
Yeah thats alot of work...... Ill just do it the way im going..... worked awsome for others....
Kyle
Originally Posted by 777
Any particular reason you aren't just going with the single breather on the driver's side. Just wondering why you need a catch can and a breather and running from both valve covers.
Its the Way Stenod has told me to do it and many other people.
Kyle
So if you have the LS6 valley cover do you need any valve cover vents or just one? I have the LS6 valley and one vent to the pass side valve cover with the drivers plugged. That is how all the LS6 style engines are from the factory I believe. Anyway, it works great...
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Originally Posted by SSblack98
So if you have the LS6 valley cover do you need any valve cover vents or just one? I have the LS6 valley and one vent to the pass side valve cover with the drivers plugged. That is how all the LS6 style engines are from the factory I believe. Anyway, it works great... ![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Good question.. Ive seen people hook them up a few different ways.
Currently I have mine where the pass side front vent is into a T where it also hooks into the LS6 valley cover... the other end of the T goes to the AMW catch can. Basically the driver side vent is still there, not capped.
Does anyone else do it like this? Or should I cap my driver side?
