Has anyone gotten tired of Forced Induction?
Old Mar 3, 2006 | 10:34 AM
MIGHTYMOUSE's Avatar
you have 4.11's; remove.
Old Mar 3, 2006 | 10:35 AM
Frost's Avatar
Originally Posted by FIREHAWK#608
I had 275 Firehawk SZ50's (factory SLP), now I have Eagle F1's.
What tires aside from BF KD's should I use? This car never sees rain and is only driven 3k miles per year. It does have to have some sidewall though
(no drag radials) because I tear up the mountain twisties as often as possible.
Thanks guys.
Keep those hard radials for mountain trips.... you aren't serious about traction in the least if you don't already have a set of drag radials. It isn't a secret that 12 second cars (and certainly faster) will destroy a set of radials, nor is it impressive...
Personally I'm about to buy some big n littles for the track, but on the street I picked nitto's 555r DRs, because they seem to be the most forgiving of water (this consensus based on ther's experiences). If you drive your car enough in the summer, soon or later you'll end up in a shower.
Old Mar 3, 2006 | 10:36 AM
Frost's Avatar
To be honest, when I saw the thread title, I took it to be a money and maint. type of thing.
Old Mar 3, 2006 | 10:41 AM
FastKat's Avatar
Looking at your sig it looks like you have some DEEP gears for street tires... I would bet your 4.11's are adding to your traction problems in 1st and 2nd. Most turbo cars run a much shallower gear... not sure about supercharged cars.
Old Mar 3, 2006 | 10:47 AM
NA$TY-TA's Avatar
Originally Posted by White.Lightning
LOL good point. So are the ET street radials a good choice for my rear tires?!?
Andy
Ill be going with the ET Street Radials on my setup bro....... and if it do get caught in the rain.... il slow way the hell down..... On my Nitto's i would slow down to about 40-50 on the freeway in a downpour.... now id probably pull off to the shoulder till it was over........ It the price ya have to pay to play.....
If you dont want to swap tires for different things then your not serious enough about traction..........................
Old Mar 3, 2006 | 10:48 AM
Spade's Avatar
My 3:73 gears and Procharger are a good match on the street. Granted I am an A4 but all the power is still controllable. Of coarse I can light them up if I wanted as well. No I will never get tired of it.
Old Mar 3, 2006 | 10:52 AM
White.Lightning's Avatar
I'm asking if I should get the ET street radials for a rear tire. I have the Hoosier QTP DOT's for the track. I am asking if I should just get the ET street radials in place of a "regular" tire since I will need to be replacing my tires real soon?
Then I will get a standard radial out front for the street.
Andy
Old Mar 3, 2006 | 10:57 AM
~JOSHUA's Avatar
I NEED the 4.11's because of the cam, it would have insane cam surge if I had the 3.42's
It already bucks if the rpm goes below 1500 on the street.
Also, my car has been in the 11's when I borrowed a set of drag radials at the track, and that's still with a 2.10 60 ft.
This car will never see rain because I check the doppler radar everytime I drive. I still need to have some side wall because straight line drag stripping isn't something I do often. I just want to be able to roll into the throttle and not have it spin?
Just curious what you guys were doing to control it. I guess the boost power delivery is a lil' different than the on/off switch I currently have.
Old Mar 3, 2006 | 11:12 AM
NA$TY-TA's Avatar
BUT.... you will be replacing this cam id you go FI and replacing the rear gears at the same time.......
Who tuned it??? doesnt sound like they did a good job.... my old cam was bigger then that and in a A4... and idled fine at 750 rpm.
It all goes hand in hand......
Kyle
Old Mar 3, 2006 | 11:19 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I know jack schitt about FI, but for tires, why don't you go with something like the Nitto 555RIIs (NOT the 555Rs)? They are supposed to have the same soft compound with a stiffer sidewall, made more for Auto-x and RR applications.
Old Mar 3, 2006 | 11:20 AM
~JOSHUA's Avatar
Nasty, it's not idle. It idles perfectly..
I'm talking about letting the engine go below 1500 in gear without the throttle cracked open at all. If it start's to buck @1450 I barely crack the throttle and it wont surge. It surged around 1800 before I got the gears.
As soon as I get married 4 months from now my budget can go toward the FI. I think that if I get a cam 220's on a 115 LSA with less gear it'll settle down, but I bet traction will still be an issue regardless.
I didn't know about the 555 RII's. I'll have to check out the feedback on 'em. Thanks.
Old Mar 3, 2006 | 11:21 AM
  #32
RyanJ's Avatar
SSU Moderator
What you need is like a LPE GT2-3, some 3.42's and FI. You cam/gears are your problem...plus the hard F1's.
If you are serious about getting FI, you might as well be serious about having two sets of rear wheels. Nitto 555R's work good, I belive some folks have used them on the autocross track. Just so you know, R-compound tires will hook better on the street than those F1's...and I mean road race R-compounds (like Nitto R2's or NT01's).
Tires, taller gears, and get rid of that big ol cam. You'll want more power.
Old Mar 3, 2006 | 11:26 AM
  #33
Xtnct00WS6's Avatar
How do sticky tires hold up on the street with the power you'd be making with FI?
Old Mar 3, 2006 | 11:35 AM
  #34
your tires, tune, gears, and driving style are all in question... there is no magic dust you can sprinkle to make traction happen (ive researched it)
follow these steps until your problem is gone
1. buy drag radials (315 bfg's or 275 mt's)
2. switch down rear gears (if requires you to change tune/cam oh well)
3. change to a more aggressive lca angle
4. lower tire pressure (i run maybe 15psi on the street out back)
5. remove front swaybar / softer springs
6. add weight (stereo, dead body, golf equip. etc.)
shameless plug (my version of a traction problem)
http://video.ls1tech.com/search/migh...C5763CB293.htm
27*11.5's, 13psi, pump gas, prepped surface, 3.42's, sway removed, qa1 drag shocks/springs, lca's lowered, 3750# as raced
  #35
i get about 7500 miles a set
Old Mar 3, 2006 | 11:36 AM
  #36
spanker's Avatar
Andy
awsome tires the mickey drag radials are badass work good in the rain is a 1.47 a good 60 foot with drag radials i think so
  #37
i just had a thought.. is it possible you are only getting one tire fire or are you two wheel peeling?
Old Mar 3, 2006 | 11:39 AM
  #38
~JOSHUA's Avatar
#4,5,6 will never happen, holding it in 3 gear around a tight corner in the mountains and stretching out the rest of the gear after the curve is the best pleasure I get out of the car. Need the swaybar, and 15 psi on drag radials around a corner will ruin the front of my car.
No the posi is great. It'll leave twin skids all through 2nd.
Thanks for the tips. -Joshua
Old Mar 3, 2006 | 11:40 AM
  #39
RealQuick's Avatar
Possibly getting smoked by a car with less than 1/2 the hp I already have is worrying me. I've actually thought of de-modding a little bit (smaller cam) to lessen the peakiness.
Sounds like you have it backwards to me...you'd want more peakiness to eliminate blowing tires away down low. Smaller cam will most likely give you better low end response which will blow the tires off.
Old Mar 3, 2006 | 11:41 AM
  #40
~JOSHUA's Avatar
I guess "peakiness" was a bad description. Sorry. More like "bulk of power that hits hard when the power curve starts." On/Off
It's pretty clear now. FI and 600 hp is good I just need the widen my rims to 11" and get some stickier rubber for the time being until the combo changes.
