Has anyone gotten tired of Forced Induction?
Old Mar 3, 2006 | 11:45 AM
  #41
RealQuick's Avatar
Originally Posted by FIREHAWK#608
I guess "peakiness" was a bad description. Sorry.
No problem, just wanted to make sure we were talking about the same things here. BTW, my little heads/cam LT1 could smoke the tires till 3rd gear with 275/40-17 stret tires (2nd gear from a roll would break everytime). I switched to 255-50-16 BFG DR's and could dead hook in 1st from a roll...no spinning even if I mashed it at 4krpm. Definitely get DR's...
Old Mar 3, 2006 | 11:52 AM
  #42
fenix99's Avatar
Restricted User
not to be an *** but duhh lol jus put some bfg's 315 drags on it and u should be good at least for 2nd gear and up i hope
Originally Posted by 93formto98T/A
Sounds like you need some stickey tires.
Old Mar 3, 2006 | 11:59 AM
  #43
~JOSHUA's Avatar
I would put 315 if I could, but my Firehawk rims are 9.5". Thanks bro.
Old Mar 3, 2006 | 12:06 PM
  #44
RealQuick's Avatar
295........
Old Mar 3, 2006 | 12:44 PM
  #45
flash12t's Avatar
just to help u out with sum info. .i have nittos555r out back and i still go threw the canyons i just make sure i up the tire pressure . . . they handle great. . well as great as they can for drs
Old Mar 3, 2006 | 01:10 PM
  #46
RAACCR's Avatar
I had these same thoughts when I was going to twin turbo my 'Vette...what's the point if it won't hook up until 100+ mph? My solution...keep the 'Vette with just bolt-ons, and build the twin turbo LSx for the Syclone. Nothing like a powerglide and all wheel drive to stick over 1000hp to the street.
Old Mar 3, 2006 | 01:15 PM
  #47
~JOSHUA's Avatar
How much pressure do you run on the street-curves?
Do the sidewalls balloon out? I have 275 tires now, should I buy 275 or 295 Nittos? Thanks.
Old Mar 3, 2006 | 01:16 PM
  #48
Tx02ssm's Avatar
I have owned 3 S/C'ed cars ( I have one now, a 98 P-1SC procharged cobra - 460rwhp @ 11psi ) and 4 turbo cars, 3 supra's and an original 87 GN. I will never tire of boost - I remember early on when I had just bought my first supra (88 turbo, bone stock and 65Kmiles) I saw a good qoute in a guy's sig --> "And on the 8th day God raised the boost..." I laughed pretty hard when I read this. Once it's in your blood it is difficult to do without it - I have done at least 4 plans now on how I will turbo/nitrous this Z28 even though I told myself and everyone else that I was leaving this one "mostly stock" - yeeeeeeah right. I can see myself eventually building a twin turbo viper HT torque moster to take to the drags and outrun the 502 big block old skul guys......
I tell you there will never be enough horse power/blot on's/perf equipment on any vehicle to satisfy me completely - my wife has certainly given up on me as a lost cause. For Valentine's day one year she gave me an apillar gauge pod with boost/temp gauges for my Lightning - "...and the road goes on forever, and the party never ends......"
Old Mar 3, 2006 | 01:22 PM
  #49
MIGHTYMOUSE's Avatar
i dont 'carve' with my car but i do not have any stability problems with my 315 dr's at 15psi. (and no front sway)
however the adjustable font shocks help the front considerably.
http://www.fastrides.com/photos/z-ra...cture2786.aspx
those are my 315's on 9.5" rims... actually a 11" rim will give you less forward bite because it will tighten up the sidewall... will certainly roll a bit more through the corner.. but you will get aware of that pretty quick just switching from regular to drag radials.
Old Mar 3, 2006 | 01:57 PM
  #50
~JOSHUA's Avatar
MightyMouse- Curious , what color paint is that on your car? Nice.
Old Mar 3, 2006 | 02:20 PM
  #51
bboyferal's Avatar
275-40-17 Nitto Dr's here. Torque Ar, LCA's, 12-bolt, etc.
If I floor it in first, I will squeal as I take off, obviously spinning but taking off nonetheless.
Transition into second can be a bit rough, but after that just light chirps... No problems hooking here with 480+ rwhp.
I hook now like I did when I was on stock power with the stock 10-bolt, suspension, street tires, etc.
Old Mar 3, 2006 | 02:29 PM
  #52
kcfan's Avatar
I want to marry your wife!
Old Mar 3, 2006 | 03:17 PM
  #53
its called carbon metallic, came on some yukons, and thanks very much.
Old Mar 3, 2006 | 03:46 PM
  #54
Firehawk853's Avatar
I ran the Nitto 275's last season. With the M6, I got it down to 1.8 60' so they did ok. I am swithing to the BFG 315's this year. However I do have to switch to 3:42 gears because my trap RPM's are too high with 3:73's. I have compromised a lot in terms of traction because I want to keep the car in the 'daily driven' catagory.
Old Mar 3, 2006 | 04:02 PM
  #55
~JOSHUA's Avatar
The gears are killing me at the track. I'm having to shift into 5th gear before the finish line.
Old Mar 3, 2006 | 04:21 PM
  #56
that tells you right there you have the wrong gear or wrong tire under the car.
set your gear or tire diameter up so that you are at max rpm in 4th gear for your goal trap speed.
Old Mar 3, 2006 | 05:00 PM
  #57
Chas1's Avatar
I was smoking the tires through 1st and 2nd until I got the MT 275's. Now I have NO traction problems at all. I don't drive my car but on weekends or good weather so I can't comment on the rain.
Old Mar 3, 2006 | 06:22 PM
  #58
TIM Z's Avatar
11 sec. Truck Mod
boost is like crack, really addictive, its what most of us day dream about. i want to custom turbo my other 2 cars ! your making awesome power with bolt ons but youll love FI for sure!
Old Mar 3, 2006 | 06:39 PM
  #59
~JOSHUA's Avatar
You can bet your bottom dollar I'm getting boosted before the end of the year. Wedding and honeymoon has to come first. Bittersweet trade-off.
You guys have been great. Thanks for spending the time. -Joshua
Old Mar 3, 2006 | 08:51 PM
  #60
The95Firehawk#250man's Avatar
my 10 bolt is freshly rebuilt, if i got MT et streets would it hold? i figure it should with no hard launching. for a while i hope, mostly from 1st gear rolls though.
