Update on my Twin-T67, 408 Build
Old 04-04-2006 | 03:15 PM
  #41
SMOKINV8's Avatar
Right below the power steering pump.
Awesome wallet! I mean car!
Old 04-04-2006 | 11:28 PM
  #42
Navy David SS's Avatar
Wink
Right on the mark!!! And they lay right next to the ABS!!
No. This is a drag car 1st, and than a Friday night cruise car very much 2nd.
Here's a couple more pictures from today. We got the injector driver in today and is wired. This will stop the "wave" effect of the injectors and hold them at a steady path.
David
Old 04-05-2006 | 08:54 AM
  #43
NA$TY-TA's Avatar
Looking bad *** David. What size tire out back?? What Trans and converter? Rear Gears??
Kyle
Old 04-05-2006 | 09:15 AM
  #44
Tiago's Avatar
Old 04-05-2006 | 09:53 AM
  #45
Lasershop's Avatar
Killer setup. Nice clean construction. You guys definitely know your stuff.
Old 04-05-2006 | 01:01 PM
  #46
TimeMachine's Avatar
Is this a wastespark system? heard AEM could only do 6 coils.
Old 04-05-2006 | 02:21 PM
  #47
Kyle
Run 30x10.5x15 on Bogart 15x10 in back. T-400 with a 4200 stall (for now). 12-bolt Moser, with spool and 3.73. We are not going to change tranny or gearing for now. We'll see how this set-up runs. May have to go to a 3.5 or 3.2 series gearing. A glide with an "auto" shifter slenoid maybe in the future, but I have to pay for all this 1st
Thanks everyone for the compliments. As said Joey has put a lot of work into the SS. The SS has finally made it to the front shop to be buttoned up - every bolt, screw, fitting needs to be tightened - and than maybe fired up by weeks end or early next week. Show is only 10 days away.
David
Old 04-05-2006 | 02:25 PM
  #48
Not sure what a "watespark system" is - Joey is building the electronics. We have a couple of other V-8's running the same system. To my knowledge - which is not a lot when come to the AEM system - they are matched up, so only 4 terminals are acually used. Maybe Joey can comment on it more.
David
Old 04-05-2006 | 02:27 PM
  #49
NA$TY-TA's Avatar
David
Dave,
Now i remember when those tires went on and you had that sig pic of dragging the bumper.
What i dont remember was what all was needed to clear thos tires...... hard? Mini tub??
Kyle
Old 04-05-2006 | 02:38 PM
  #50
Dave,
Kyle
That be me That little wheelie cost me a bunch - never got my 9's on stock bottom end . Oh well, it led me to do the turbo build about a year or two earlier than I wanted. Now I can't wait to drive the beast. It should be wild on the street
Had to:
- cut lower half of outer rear fender wells 2-3"
- remove bump stops
- BFH mod
- re-shape the inter part of the rear fender wells with some sheet metal - next step is mini-tub
Rear end is narrowed about 1.5". B/S on wheels are 6.5". Tucks very well.
Rear springs are stockers that have been cut.
Here's a recent picture of the ride.
David
Old 04-05-2006 | 03:20 PM
  #51
NA$TY-TA's Avatar
Had to:
- remove bump stops
- BFH mod
David
That rear tire is huge.... looks badass..
Old 04-05-2006 | 04:30 PM
  #52
LASTLS1's Avatar
6 Second Club Moderator
It looks real nice. That should be a lot of fun!
Old 04-05-2006 | 04:46 PM
  #53
SSilverSSurfer's Avatar
Fuel system: Summit fuel cell, Aeromotive fittings and braided lines, Aeromotive Eliminator Fuel pump, Aeromotive in-line filter, and a couple of Aeromotive Y-blocks. Injectors are 1000cc.
The entire car is controlled by the AEM system.
David
what made you go with the AEM system?
Old 04-05-2006 | 10:28 PM
  #54
SSilverSSufer
Experience of my sponsor/tuner/fabricator/mechanic - Joey from Excessive AutoSports. He is very experienced with AEM, and we have never seen anyone from up here run a BS system. And no way was the stock PCM going to handle this tune.
Final fuel system and water tank plumbing was finished today. 1 day closer to firing this bad boy up.
David
Old 04-05-2006 | 10:31 PM
  #55
Thanks. By your signatures your's looks very stout also
This year has the appearance of an outstanding season. I can't believe how many people are going turbo - and big ones at that.
Should be a blast.
David
Old 04-06-2006 | 12:47 AM
  #56
TrakDay's Avatar
One day I will own something like this! Very nice Work!
Old 04-06-2006 | 08:30 AM
  #57
Thanks. This has been a "dream" of mine for the last 5 years. Finally
David
Old 04-06-2006 | 09:39 AM
  #58
LASTLS1's Avatar
David
It's nice to see that, not only did you do it!! But you did it right!!! You didn't mess around.
Old 04-06-2006 | 03:24 PM
  #59
Considering this is the LAST build on this car. Thought I would try to do the SS justice is deserves.
Thanks again
David
Old 04-06-2006 | 11:18 PM
  #60
GenIIINova's Avatar
Default comparable to my project...
I am building a 6.0 for turbocharging right now. I also am an AEM dealer/Tuner. The EMS is bad-***. What EMS box, ignition box, and wiring harness are you using? I have a 1050 box, MSD DIS4 and the P&P kit. Why no LS1-style intake? Nor a Sheetmetal?
Good fittment. I do like the intake setup, by the way.
Quick Reply: Update on my Twin-T67, 408 Build
