NEW front mount turbo pics!!
Old Apr 20, 2006 | 01:10 PM
Mr_president's Avatar
Default NEW front mount turbo pics!!
well i had the old phamspeed exhaust and hated it! had to drive slower then my grandma! so i didnt listen to what people said! and DECIDED ill like the phamspeed style and tryed it well you know the result!
DO IT RIGHT THE FIRST TIME GUYS TRUST ME! SPEACILY IF YOUR EVER RUNNING SKINNES AND MEETS!
-1 for any uner the k member exhaust!
HERE ARE THE NEW PICS OF THE NEW EXHAUST AND ENGINE BAY WITH METHONAL RUNNING FROM THE WASHER FLUID TANK
Old Apr 20, 2006 | 01:30 PM
Parker TX's Avatar
Thats a very good looking setup you got there.
Old Apr 20, 2006 | 01:36 PM
SHINER's Avatar
niiiiicccceee
Old Apr 20, 2006 | 01:37 PM
ill have DYno number tommorow from synergy!! taking it to get it dyno tuned!!!!
SHINER's Avatar
oh ya are you sure that band clamp is gonna hold on your turbo? I ad those for my ORY extension pipes and the broke cause of heat and pressure.
Old Apr 20, 2006 | 01:47 PM
ddnspider's Avatar
do u happen to have a pic of where the DP goes ?
Old Apr 20, 2006 | 01:52 PM
RICE ETR's Avatar
Turbo Addict
That's what i learned the hard way too...and why i made my second kit over the K-member and ran nothing under the tranny either. I got tired of bottoming out and crushing my piping on ever little bump, high spot in the road or bridge overpass.
Old Apr 20, 2006 | 01:53 PM
RICE ETR's Avatar
Turbo Addict
Oh...is the turbo high enough to allow for proper draining? The pic might be a little misleading.
EDIT... i realllllly like the hood! Where did you get it?
Thanks
Old Apr 20, 2006 | 02:20 PM
RyanJ's Avatar
SSU Moderator
yeah, it looks like the tubing goes up from the turbo to the pan. Nice setup though. Did you just redo a pham header-type kit and put the dp/tubing above the k?
Hood is VFN it looks like (search for "Sunoco" in the appearance or Texas sections for pics).
Shinerbock...what are you talking about? Maybe I'm missing it.
Old Apr 20, 2006 | 02:44 PM
NA$TY-TA's Avatar
Looks good man.....Any pic's straight on from the front of the car's engine bay???
Kyle
Old Apr 20, 2006 | 02:52 PM
WestSide's Avatar
Bad *** man!! Get some video
Old Apr 20, 2006 | 02:54 PM
bc56f100's Avatar
check out the video in his sig!! Sounds kick a$$ man!!!!!
Old Apr 20, 2006 | 03:19 PM
that was with my old set up in the video! But ill get some video of the dyno and a bucnch of me racing when its done ! for now thesee are the only pics i have ! thanks guys for the responces! yes that is a sunoco hood from vfn!
Old Apr 20, 2006 | 03:22 PM
frcefed98's Avatar
Told you guys that the pham kit sucks for ground clearance. I tried like a **** to watch every bump and slow down for them, but no matter what..I'd still smack the tubing
Reason why I ditched the whole set up(besides not being able to change the plugs) and built my own truck manifold kit.
Tond, it looks great, you have a nice looking camaro. Hope you get some decent results tomorrow. Rick will take good care of you
Old Apr 20, 2006 | 03:26 PM
yea im hoping for high 500s on 8 psi with meth... i have ported heads lq9 heads and this cam 218 214 564 546 115lsa + 5
Old Apr 22, 2006 | 12:48 AM
UPDATE!!!
well i drove 3 hrs to synergy and my luck he coulnt get it past quatert throttle with out my cluch slipping bad!!
time for clutch and new gears! hopefully be back there in a week or so!
Old Apr 22, 2006 | 07:49 AM
WestSide's Avatar
Originally Posted by TondSS
UPDATE!!!
what clutch were you running?
whatcha going to?
Old Apr 22, 2006 | 05:58 PM
im running just a regular ram clutch i had a spec 3 and hated it blew it in a months......maybe a spec 5
Old Apr 23, 2006 | 10:55 AM
NA$TY-TA's Avatar
How long was the Ram in there for?? The RAM VDS might hold it well. I dont trust SPEC at all.....
Try Textrailia.
Kyle
Old Apr 23, 2006 | 11:06 AM
ddnspider's Avatar
how is that possible?i had my spec 3 for over 40000 miles of abuse,i was on the bottle then too and it help up just fine.Ater i took it out for my rebuild a buddy actually used my pressure plate cause it was still in decent shape.
