Intake That Wont Crack At High Boost?
Old 05-10-2006, 09:58 PM
MyWs62FaST4u's Avatar
Default Intake That Wont Crack At High Boost?
like it says, which one to go with for 15+ pounds...? fast with burst panels>? or sheetmetal>?
its gonna be a 91mm on a 418cid Ls2 build, for starters...
Old 05-10-2006, 10:03 PM
BLk01SS's Avatar
If price is an issue, just get a Weiand or BBK. Next on my list would be a FAST. There's a lot of people still using LS6 intakes though. Even with that much boost
Old 05-10-2006, 10:48 PM
93formto98T/A's Avatar
My ls1 intake blew to pieces at 8lbs of boost!! LOL j/k. I'm currently running 17lbs w/stock ls1 intake and going for 21 soon.
Old 05-10-2006, 11:15 PM
Jammer's Avatar
Rann 22lbs for a few moments on a ls2... yes the ls2... now I run 10 lbs alot... no issue w/ intake.
Old 05-11-2006, 07:20 AM
Super Moderator
Reckless's Avatar
Well Mike Brown runs 28psi on his LS6 intake, so I am not sure what to tell you
Old 05-11-2006, 07:24 AM
NA$TY-TA's Avatar
If your going to stay with a stock style intake the FAST intake is a big waste of $$
Just like Todd said... stick with the LS6.
Old 05-11-2006, 08:31 AM
NoGo's Avatar
<----- intake has been living comfortably at 17 psi for quite some time now.
Old 05-11-2006, 10:39 AM
Z06PSI's Avatar
How do you like the LS2 on a boosted application. I know N/A they suck but for F/I I think they will work great. I have and going to use it if I use a LSX engine. The other alternative is the new L92.
Old 05-11-2006, 05:37 PM
so your advice is to get a nice ported LS2 style intake?
ditch the fast90, and forget the sheetmetal.. im only planning on 18lbs for myself on the street, on the LS2 stroker...
Old 05-11-2006, 07:32 PM
2001-WS6's Avatar
Yes, the LS2 intake works very well for FI. It's been to 17lbs for testing purposes.
Rick
Old 05-12-2006, 11:34 AM
Dave D's Avatar
has anyone tried the forementioned BBK??? Sounds like a good piece.
Old 05-12-2006, 11:49 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,113 Likes on 730 Posts
LS6 for me right now, 18-21psi. Going to Edelbrock single plane soon. I would probably avoid the FAST 90 for big boost, given that it's a multi-part intake.
Old 05-12-2006, 12:41 PM
true true, so a ls6/ls2 intake seems the route for me to go down, avoid aluminum due to potential for heat soak, correct?
Old 05-12-2006, 12:42 PM
whats ur new combo gonna be>? how did u like your 88mm?
Old 05-12-2006, 01:48 PM
LS1Tech Co-Founder
Will be:
348ci, 8.2:1
GT47-88
A/A front mount intercooler
Turbo is not on yet.
Old 05-12-2006, 02:45 PM
smokinHawk's Avatar
either an ls6 or a single plane for FI, anything else is a waste.
Old 05-12-2006, 05:51 PM
LS1Tech Sponsor
hellbents10's Avatar
Old 05-14-2006, 04:09 AM
Dave D's Avatar
No love for the BBK 85 mm??
Old 05-14-2006, 07:46 AM
Big Mike's Avatar
I will be running an LS6 intake on my setup. 94mm turbo and we plan on pushing at least 25+ PSI. The motor will be a 370 ci iron motor.
Cartek has their TT Z06 running twin 67's with the LS6 intake. 22-24 PSI without a glitch!
Quick Reply: Intake That Wont Crack At High Boost?
