GLM Tuned 382/Vortech (719hp 757tq)
First I would like to thank Bob and Brent at Exotic Performance Plus for the use of his dyno on this.
Quick run down of the mods as I know them. I didn't build the car, just tuned it with EFILive Custom 2bar OS.
Built 382
Vortech T trim 13lbs
80shot N20
M6 with 3.42's
I have enclosed both Motor only and N20 graphs. Needles to say I am VERY happy on the numbers from this car considering it is on a mustang dyno.
Motor - 637/665
Motor+N20 - 719/757
Timing was consertative as well as the AFR. I could have pulled some more out of her, but I wanted to leave it safe for the customer.
Built 382
80shot N20
M6 with 3.42's
Motor - 637/665
Motor+N20 - 719/757
Originally Posted by DeltaT
What is a V-trim? I see no listing for it on Vortech's site. They are all named V-#, where # is the series (V-1, V-2, etc.), not the trim.
Jim
Jim
i'm thinking its probably a T trim, my friend made similar numbers on a built 382 with a T trim.
Those are exceptionally high numbers for a V-1 on a 382, Mustang dyno no less! And a non-sprayed power peak of 5360 with a centrifugal?
Any idea what cam was in there?
Jim
Jim
The V-1 is the S & T trim. It is most likely a T. The numbers look right. MelloYello made 650 with his T. I believe I would be over 600rwhp if the car was a stick.
The T would put it right in that number range.
I'm looking forward to the details...
Jim
Good numbers. I wish I would have done a 383 now seeing that TQ. For sure that is a V-1 race m T trim. What size off pulley? I think with a 2.85 you get 13psi. Im using the 2.95 pulley right now with 11 psi.
so what's the deal with this car? i know this is 2.5 years old. what kind of cam did he use? also did he go with the eagle 4" crank? what heads etc? and what is the pulley i should roll with to get about 16 psi max out of a f1 procharger? my goal is about 700 to the WHEELS without spray. I wanted to build to a 382
