Whats the RWHP record with a F1R?
Old 06-04-2006, 02:09 AM
Gayard's Avatar
Default Whats the RWHP record with a F1R?
I have a F1R and just ordered a 3,80 pulley! I hope I get in the 800 rwhp range.
Whats yours numbers??
Old 06-04-2006, 07:12 AM
Administrator
unit213's Avatar
I know of a 408 with a F1R in the 800rwhp range.
Old 06-04-2006, 08:15 AM
LS1Tech Sponsor
Slowhawk's Avatar
Damn,3.80
We got 770rwhp from a 346 with a 4.25" pulley on pump gas. Our race cars have hit 1050rwhp with the F1R and A3 tranny's.
Old 06-04-2006, 10:02 AM
2MuchRiceMakesMeSick's Avatar
You will not have a problem hitting your goals with that blower/pulley
Old 06-04-2006, 11:34 AM
Gayard's Avatar
Originally Posted by Slowhawk
Damn,3.80
1050 rwhp!? That sounds great! Maybe I can hit 900 rwhp whit that pulley?
My motor specs are:
347 cui forged 8,5-1 CR ( hoping for 20 psi)
ET 240 heads
F1R, 8 rib, 3,8 RR
FMIC 4 inch thick
224 228 58? 114
ECS fuel system
75 injectors
LG headers no cats
M6 gearbox
What do you guys think?
Old 06-04-2006, 11:46 AM
OldBlue's Avatar
First thing that stands out too me is the camshaft. Seems to be a bit small for the type of power your wanting to make.
Just my opinion though.
Old 06-04-2006, 01:45 PM
LS1Tech Sponsor
Slowhawk's Avatar
My motor specs are:
ET 240 heads
F1R, 8 rib, 3,8 RR
FMIC 4 inch thick
224 228 58? 114
ECS fuel system
75 injectors
LG headers no cats
M6 gearbox
Unless this is a race car I would rather run compression at 10-1 and use a D1 on that Combo.
Also add a Carb intake and smaller cc heads
Old 06-04-2006, 03:43 PM
93formto98T/A's Avatar
your injectors will likely be maxed out before 900rwhp. The 60s I have are good to ~750rwhp and I'm going to have to go 83 or 96 for the 900.
Old 06-04-2006, 04:30 PM
Gayard's Avatar
My plan is to upgrade to a LS2 block later, but now I just want to see how much boost my 347cui can take. Thats why I have those big heads and F1R
Im happy as long as I have 800 rwhp or more.
What is a Carb intake?
Old 06-04-2006, 05:12 PM
Quickin's Avatar
whats the most RWHP that an F2 will produce on say a 408 or 422 engine?
Will it fit and still allow me to keep A/C?
Old 06-04-2006, 05:29 PM
kwman's Avatar
The 1050 rwhp car, I have to ask the dumb question as my knowledge of S/C pulley to boost ratios...sucks. Anyway at what Bar or PSI does this car make 1050 rwhp? If you don't mind me asking...
Old 06-04-2006, 06:00 PM
LS1Tech Sponsor
Slowhawk's Avatar
Seamed like our F1 car liked 16lbs. We ran 18lbs and it would lift the heads at the track on pump gas.
Old 06-04-2006, 06:01 PM
LS1Tech Sponsor
Slowhawk's Avatar
It's not really boost.It's engine combination. Compression,Cam/Head selection.
Old 06-05-2006, 12:32 AM
TT-TECH Veteran
Inspector12's Avatar
My motor specs are:
ET 240 heads
F1R, 8 rib, 3,8 RR
FMIC 4 inch thick
224 228 58? 114
ECS fuel system
75 injectors
LG headers no cats
M6 gearbox
If you are really going to get 20 PSI going to your car then I would say that looks ok. Cam is ok in my opinon, but a different cam could help if you talk to a good cam company to help out with some of the technical sides of picking a cam. Good luck!
Old 06-05-2006, 02:20 AM
TrakDay's Avatar
I went with the F1C blower... and I plan on running a 3.85" pulley on my 408/ET240cc head setup. I am expecting over 800rwhp for sure, and honestly would be more than upset if it did any less!
Old 06-05-2006, 07:32 AM
SSilverSSurfer's Avatar
like a GMPP or a victor jr. check out intake elbows.com they pics and stuff like that
Old 10-27-2006, 07:05 AM
LSs1Power's Avatar
My motor specs are:
ET 240 heads
F1R, 8 rib, 3,8 RR
FMIC 4 inch thick
224 228 58? 114
ECS fuel system
75 injectors
LG headers no cats
M6 gearbox
Do you have an F-body? Did the F1R fit the J-bracket? Did you have to do any sort of custom work to fit it there?
Thanks
Old 10-27-2006, 08:35 AM
koji777's Avatar
F1R here, 800rwhp no prob.... no mod to j bracket
Old 10-28-2006, 01:44 AM
BLASTER's Avatar
Why just a D1 with such high compression?
Old 10-28-2006, 10:22 AM
7 Second Club
ty_ty13's Avatar
hp and torque comes on quicker....
Quick Reply: Whats the RWHP record with a F1R?
