wow crazy 99 pcv (not) valve
we put on my old oil fill breather and i was starting to describe how my pcv set up goes. i pulled out his pcv valve and found this!
the damn thing is hollow! no valve in it at all.
not only does this not vent the crankcase well at vaccum, but it allows straight boost to go into the crankcase!
we replaced it with a regular pcv valve and his crank vaccum increased and now 'mostly' seals under boost.. shouldnt rely on a stock pcv valve for that.. but at least it has my valve cover breather to let it out now.
I can't believe it.. must have been some quick fix gm tried to limit oil consumption?
check it out.. anyone that still uses the stock pcv valve and has never looked at it, please check it out!
anyone have any more info on this?
i figured it was to reduce oil consumption if anything.
weather you have this valve or a stock regular pcv valve you HAVE to put a better 1 way valve that seals completely under boost in line with it OR ditch the system all together for something else.
at least you have the breather to let the boost out
Some people will put anything in their mouths
