which will make more power front vs rear
ill post up when i get everything on and tuned
Some front mount setups require the AC to be relocated. You'll see higher under-hood temperatures with it under the hood also and higher IAT's than an STS, because the charge pipe has so much distance to dissapate heat, but at the cost of some lag. I'm overall very happy with my rear mount T70, and it's a fairly good sized turbo for a 346.
i beleieve the front is better, but its just me. never did a rear mount before tho. when its in the front the exhaust has the most energy which would be good for the turbine
You are kinda showing some ignorance here dude. There are some decently quick rear mount cars in here. Well into the 9's, which is nothing to sneeze at.
back or front of the car doesnt matter.. its the dimensions of the pipes and way they are put together.
i've never seen any proof in engineering school or in real life supporting the thought that a turbo further away from the engine can be advantageous in making hp
you can definitely take a car that can run 9's on motor and still manage a 9 with an sts style kit.
This will be an interesting post to watch.I will offer my humble opinion... wanted or not. Physics determines that a side by side comparison will yield that a rearmount cannot make the same power that a front mount does. It is a matter of heat retention... until we invent a "Zero temp loss" system, rearmounts just cant get the same type of air that a front mount does. For more info read our thermodynamics conversations in the other posts on this board.
Now for arguments sake... I am building what I hope will be a 900RWHP rearmount setup. But I know what I want... and I have a good plan on how to approach it. But I dont think I could ever match one for one a front mount... apples and oranges IMHO.
Mike
