BOV location
Old Aug 13, 2006 | 09:05 PM
mlambrecht82's Avatar
Default BOV location
I am building a custom FM turbo kit with a FMIC for a LS1 camaro I am wondering the best placement for the BOV I am thinking before the intercooler so that the intercooler does not get a surge of hot air between shifts. But then I am also thinking right before the throttle body so the intake air velocity is not disrupted between shifts. If right infront of the TB is the best placement, should I put it on the 4" Stainless Steel elbow so that when the BOV is open the air has a easy direct shot out- but BOV on the outter radius may cause some unwanted turbulence. Or should I put it before the elbow so the turbulence is not as great but the air will have to make a bend to go through the BOV. Thanks in advance for the input.
Old Aug 13, 2006 | 09:36 PM
MyWs62FaST4u's Avatar
id like that input as well...lol...
Old Aug 13, 2006 | 09:48 PM
ninetres's Avatar
Whose kit are you building
Old Aug 13, 2006 | 10:24 PM
Your moms...
Old Aug 13, 2006 | 10:30 PM
ninetres's Avatar
Originally Posted by mlambrecht82
Your moms...
Lucky bitch
Old Aug 13, 2006 | 10:33 PM
LOL...don't worry she's paid in full!
Old Aug 13, 2006 | 10:37 PM
ninetres's Avatar
Sounds like you're taken care of then.....I'll make sure your woman isn't lonely
Enough bs though, lol. This is (or was) a serious thread!
Old Aug 13, 2006 | 10:38 PM
Camaro_Zach's Avatar
but your mom = his woman...so youre going to make sure your mom isnt lonely....gross... haha jk
Old Aug 13, 2006 | 11:23 PM
LOL you got him good...enough though back to the point. Can anybody at least tell me if it is recommended to have the BOV pre or post IC
Old Aug 14, 2006 | 12:09 AM
cws T/A's Avatar
I think as long as its before the MAF your golden
Old Aug 14, 2006 | 12:23 AM
ninetres's Avatar
This will be a speed density car.
Old Aug 14, 2006 | 02:06 AM
2002/Black/SS's Avatar
from things ive heard, closer to turbo less strain on the turbo,and closer to TB less strain on engine..... (but i dont really understand the less strain on turbo part)
Old Aug 14, 2006 | 02:13 AM
ninetres's Avatar
So the debate continues........
Old Aug 14, 2006 | 07:46 AM
bowtieman81's Avatar
I believe Harlan and W2W have recommended it after i/c. That is where mine will be, and I believe most of the turbo kits you can buy locate it there.
Old Aug 14, 2006 | 09:01 PM
fenix99's Avatar
Restricted User
mines is after intercooler...before MAF; a few inches away from the MAF on a 3" elbow and i had to adjust the BOV because i was tweaking it the other day and i think i adjusted it toooo much and everytime i would rev the car and the BOV would sound, the car would come back to idle and stumble(im thinking due to so much air leaving the charge pipe and not being read by the MAF, but i adjusted it and everything seems to be fine, just wish my BOV was louder , maybe i just need to boost more good luck hope this helped
Old Aug 15, 2006 | 06:21 PM
MiaSSmaro98's Avatar
albert u connected everything already?
Old Sep 28, 2006 | 12:22 AM
Mr_president's Avatar
up real curious!! mine is befor in the intercooler!
Old Sep 28, 2006 | 11:27 AM
Oh shoot you are screwed!!!
Old Sep 28, 2006 | 11:36 AM
ABeasst's Avatar
I believe harlan said that he preferred to put it before the intercooler to keep from getting cracks in the welds on the endtanks. However I believe that would only be a big problem on cars making big power with big boost.
Old Sep 28, 2006 | 02:13 PM
bboyferal's Avatar
More boost WILL fix that.
