pcv idea
Old Aug 20, 2006 | 03:33 AM
navymitch12's Avatar
Default pcv idea
Well I am sitting at work thinking about my pcv system and what to do with it to make it better....and than I got a random idea that I think might work....
Here is what I got going on in my head...I have an sts system and as of now was going to run the valve covers to a catch can and than a line from the catch can to pre turbo. well I don’t really want to run a line all that way...I already have like 4 going back there. So I am thinking and well I have the air pump off my car right now...well what if i were to reverse the plugs on the air pump to make it suck air and than run the catch can to that? Or just run a switched 12v to the air pump....would that work? How much power does the air pump actually have? I am thinking a lot just because it has to pump air into the exhaust so its fighting against back pressure...so if I just reverse its polarity would it suck enough to work like a scavenger pump?
This could be a really retarted idea but I had to ask.
Old Aug 20, 2006 | 03:35 AM
red90cobra's Avatar
lol do a search it's been asked alot bout the using the air pump as a vacumm pump
Old Aug 20, 2006 | 03:36 AM
really...i have totally never seen it b4...
i guess i should have searched it b4 i posted....o well
Old Aug 20, 2006 | 03:37 AM
red90cobra's Avatar
no biggie it's late i'm tired or else i'd link the thread for you
Old Aug 20, 2006 | 03:44 AM
BOONE's Avatar
Default air pump
Quick summary is: its too weak. Not enough suckie suckie.
Old Aug 20, 2006 | 03:47 AM
yep thats what i am gettin....o well guess i am running line back to the turbo
Old Aug 20, 2006 | 04:14 AM
SilverSS's Avatar
https://ls1tech.com/forums/forced-induction/524125-anyone-try-crankcase-evac-set-up.html
i run this after the turbo's exhaust with a catch can in the engine bay. seems to work pretty well.
Old Aug 20, 2006 | 06:02 AM
do you have a wideband o2?
can i get a pic of where you put the nipple?
what type of hose/line did you use to run it upfront to the catchcan?
Old Aug 20, 2006 | 07:26 AM
Boostaholic's Avatar
I run a air pump in addition to other methods with good results so far
Old Aug 20, 2006 | 08:28 PM
can i get some more info on that?
