Oil Restrictor Where?
Old Sep 5, 2006 | 12:40 AM
JerikSS's Avatar
Default Oil Restrictor Where?
I need an oil restrictor but dont know where to get them???? where???
Old Sep 5, 2006 | 12:49 AM
JerikSS's Avatar
what size for a t70 as well?
Old Sep 5, 2006 | 01:04 AM
Phate's Avatar
There is a place here in California that actually pre-drills the feed fittings for the correct size restrictor so that you don't need another part. PM me if you want the name and address of the place (they are not a sponsor).
Old Sep 5, 2006 | 02:52 AM
SuperZ's Avatar
I just used a nitrous jet and put it in the feed line wheere the line screws on to the turbo
Old Sep 5, 2006 | 06:18 AM
Country Boy's Avatar
Senior Member
Look on the major auction site for the Function7 piece. It bolts to the turbo and has the nipple on it.
The restrictor is made into it.
Old Sep 5, 2006 | 03:15 PM
MiaSSmaro98's Avatar
how do u know if u need one?
Old Sep 5, 2006 | 03:48 PM
Willem @ Fuel Injection Concepts's Avatar
everyone needs one technically. most people are overfeeding their turbos with oil.
thumbs up for function 7, we use em for some of our cnc stuff.
Old Sep 5, 2006 | 03:50 PM
any link to his products
Old Sep 5, 2006 | 03:54 PM
eBay, search for function 7
Old Sep 6, 2006 | 04:18 AM
Silverback's Avatar
What is this statement based on? All turbos have restricted passages internally going to the bearings and I don’t see any good reason why you should need more of a restriction then that unless you have too much oil pressure or too little a return. Most turbos are designed for 65-70psi or less oil pressure so that could be an issue, but assuming that they have a big enough return to a low pressure area they should be fine with whatever oil you could force through them at roughly between 30-65psi
Old Sep 6, 2006 | 01:45 PM
already search,he has nothing for sell
Old Sep 6, 2006 | 02:04 PM
bowtieman81's Avatar
http://cgi.ebay.com/ebaymotors/Funct...spagenameZWDVW
Search ebay for function7 (no spaces)
I just bought one of these, should arrive Friday.
Old Sep 6, 2006 | 02:14 PM
thanks for the link i though his member name was function7 thats why i couldnt find nothing
