is a t76 to small?
Old Oct 31, 2006 | 03:48 PM
allthrotle's Avatar
Default is a t76 to small?
Do you think a t76 is to small for a 7.5L engine? Im needing opinions. the catch is Im only spinning this thing up to 6500rpm. bore size is 4.352
Old Oct 31, 2006 | 03:59 PM
Stupid Boost's Avatar
Only way a 76mm would work , is if was a S76. They use a big turbine wheel. They now have a new LDP "Low drive pressure" wheel. Which is suppose to be made for high backpressure situations.
A standard 76 will drop like a rock on that size of a motor.
Old Oct 31, 2006 | 05:52 PM
Zombie's Avatar
T76 = too small. I'm not even able to make it to 6500 rpms on my 370 at 15psi. I can do it on 12psi.
Old Oct 31, 2006 | 06:02 PM
CHRISPY's Avatar
T6 flanged T88 will work MUCH better than the T76 if you are going to 1.8 bar and up.
Old Oct 31, 2006 | 06:57 PM
engineermike's Avatar
You will usually find me advocating the use of the T76 on larger displacements than most. I believe that it will do reasonably well up to 400 cid, whereas most say to cut it off at 350 cid. However, 465 cid I even believe is too big for it. The T6 flanged will do better, but ideally you would need a T6 flanged 88 or 91, bigger if it's drag-only.
Mike
Old Oct 31, 2006 | 09:21 PM
Turbo LS1 SS's Avatar
hell no. thats thumper territory unless your doing twins. the only way a t76 would work is if there were 2 of them
Old Oct 31, 2006 | 09:58 PM
ninetres's Avatar
Now were talkin
Old Nov 1, 2006 | 12:22 AM
allthrotle's Avatar
thanks for the input guys. Im only going to be running 14lbs. it should run pretty good with that.
Old Nov 1, 2006 | 09:08 AM
DrTurbo's Avatar
LS1TECH Sponsor
Go with an S80 or S85 for only that kind of boost.
Old Dec 2, 2006 | 06:41 AM
MyWs62FaST4u's Avatar
hell yes!
Old Dec 2, 2006 | 06:51 AM
LS2Camaro's Avatar
Two S88's would be even better.
Old Dec 2, 2006 | 06:55 AM
LS2Camaro's Avatar
But Seriously, take the Doctors (DrTurbo) advice.
Old Dec 2, 2006 | 09:01 AM
DrTurbo's Avatar
LS1TECH Sponsor
Correct, the S80 would work, but the 85 is probably a better canidate. 6500rpms on a 7.5L engine is ALOT of air if it has heads that are worth any count.
Old Dec 2, 2006 | 09:42 AM
NA$TY-TA's Avatar
With a 76mm turbo i dont think you would even get to 14psi...... ive been there LOL with a T6 Flanged 76mm turbo.......
With those cubes id go with an 88 or bigger.... for quick spooling and a blast to drive.... id bet over 800rwhp at 14 psi with an 88......
Old Dec 2, 2006 | 10:14 AM
Toonz's Avatar
Have to agree with my little brother above... you'll need something a bit bigger than the 76.
Old Dec 2, 2006 | 10:56 AM
LS2Camaro's Avatar
Question, what engine is that you have that is a 7.5L? Chevy BB right?
Old Dec 2, 2006 | 11:26 AM
notatruews6's Avatar
Has Unresolved Sales In Feedback/12 second club
101mm
