high HP, what recommended mods for Oiling system?
Old Nov 7, 2006 | 02:22 PM
obZidian's Avatar
Default high HP, what recommended mods for Oiling system?
just wanted to see what is recommended when reaching high hp levels, 800-1000rwhp or more. will stock wet system be sufficient with proper care or will a dry sump be necessary?
How about a scavenge, high volume pump that picks up after our stock system and supplies more oiling to the engine? Something that compliments the stock system without having to deal with the high cost of a complete dry sump kit.
thanks!
Old Nov 7, 2006 | 02:46 PM
obZidian's Avatar
WOOOO HOOOO!!!
2000 posts!!!!
Old Nov 7, 2006 | 05:19 PM
NA$TY-TA's Avatar
Im running a Melling Pump, stock pan........ i have TON's of Oil Pressure....
80-90 psi @ WOT.... restrictor inline to the turbo
Old Nov 7, 2006 | 05:23 PM
fash00's Avatar
An accumulator is cheap insurance.
Old Nov 8, 2006 | 12:08 AM
obZidian's Avatar
whats up fash?! Trans is almost in....
anyways, i was looking at the canton unit. have had in mind ever since i saw it in an article, that system has been on the back of my mind.
Well, i do have a ported pump and my oil pressure is pretty solid for n/a. But i want some more headroom with this much power.
Kyle, that pump suppliments your stock oil pump? Is that gear driven? Any pics of how it is installed?
So is a dry sump almost overkill or necessary for this range of power?
Old Nov 8, 2006 | 12:18 AM
eviltwins's Avatar
A dry sump is totally overkill for 1000 RWHP. I've made 400 RWHP more than that on a stock volume/stock pressure small block ford oil pump with no issues. Not a lot of people even run dry sumps for drag cars.
Old Nov 8, 2006 | 12:43 AM
fash00's Avatar
oh **** i didnt even recognize it as you haha lemme know how that thing does
Old Nov 8, 2006 | 10:36 AM
sb427f-car's Avatar
SSU'S Vice Mod
The only real reasons you NEED A dry sump:
1) you turn left and right A LOT!
2) You setup to oil the valve train through the vavle covers
3) you are looking to help creat vacume in the crank case to free up horsepower
4) you have lots of money.
High flow oil pump, good crankcase vent setup, and an accumulator (if you're concerned about loss of oil pressure) will do ya.
