Boost ??
Old Nov 25, 2006 | 09:45 PM
kllrvet's Avatar
Default Boost ??
I have a 2005 GTO with an STS kit installed. It has a GT67 turbo with the STS intercooler and it also has a Devil's Own Meth kit as well. So far that car has shown just a hair over 500rwhp(with a poor tune). It made 7lbs on the dyno, and shows 9lbs on the street.
The car now has a 2 bar SD tune and runs seemingly safe on the street (A/F 11.5-10.9). What I want to do, is turn the boost up to about 11lbs. I just don't know if the motor will live okay. Anybody have any experience boosting an LS2?
Thanks in advance
Tony
Old Nov 26, 2006 | 07:31 AM
kllrvet's Avatar
To The top for the AM crew
Old Nov 27, 2006 | 08:07 AM
kllrvet's Avatar
Anyone have an opinion?
Old Nov 27, 2006 | 08:36 AM
SleeperZzZ28's Avatar
from what I understand LS2's are better at handling boost than the ls1 and there are several guys pushing over 11psi on a stock block ls1. I think youll be fine with a good tune and you should put down some good numbers.
Old Nov 28, 2006 | 10:03 PM
kllrvet's Avatar
Thanks for the reply. Any others have any experience/opinions? I am really wanting to try this, but fear wrecking my engine. I may let this pass for a while until I have $$$ to fix it if it turns out like this one:
https://ls1tech.com/forums/forced-induction/614784-cracked-block-broken-piston.html
Tony
Old Nov 29, 2006 | 07:37 PM
kllrvet's Avatar
bump!
Old Nov 29, 2006 | 07:43 PM
mahhddgtp's Avatar
You should be fine, especially with meth. Just fix that tune.
Old Nov 29, 2006 | 07:59 PM
kidcamaro98's Avatar
im putting 10-11 psi on my stock 3.8 v6 motor with a T70. As long as you have the fuel there and a decent tune...it will not be a problem.
Old Nov 29, 2006 | 08:02 PM
Frost's Avatar
I mean you are talking about adding fuel in the tune and turning it up, not just upping the boost and going with it right?
Old Nov 29, 2006 | 08:03 PM
Frost's Avatar
....although if you are 2bar and it's mapped right you should be ok... how do you feel about your fuel under boost adder?
Old Nov 29, 2006 | 08:40 PM
kllrvet's Avatar
The tune has been great. I was just looking for opinions. I didn't want to push my stock motor over the edge. I have a 12 gph meth nozzle in it now, and will upgrade to a 14 if I do up the boost, as well as rework the tune.
Thanks,
Tony
Old Nov 29, 2006 | 09:14 PM
TopRPM's Avatar
I would get a dyno tune... and you should be safe....
Intercooler and Meth should take care of any detonation on 11psi..
Old Nov 30, 2006 | 07:19 AM
kllrvet's Avatar
I have a wideband installed in the car, so I can street tune it, and get the best tune possible. I'll also save a few $$$ on the dyno rental.
Tony
Old Nov 30, 2006 | 07:51 AM
StoleIt's Avatar
NKAWTG...N
You still have stock fuel system? If so I wouldn't do it. Also, make sure you keep the meth full, you let it run out and boom there goes the motor if your in boost.
Old Nov 30, 2006 | 08:17 AM
kllrvet's Avatar
I have Motoron 60lb injectors, and a 255lph intank pump. I have enough duty cycle left in the injectors to increase the boost, so fuel shouldn't be a problem.
I do keep the meth topped off all the time, but it really doesn't go through too much.
Tony
